ValenciaPilgrim
Burping Jelly Baby
Tue Sep 05, 2017 4:11 pm
Hi I am trying to figure out the Burping Jellybaby activity so I can do it with my teen code club at the library.
https://projects.raspberrypi.org/en/pro ... jelly-baby
Everything seeems to go right, until the very end. When I try to run the program by clicking on Run and Run Module (in Python 3), this error message comes up in red:
File "/home/pi/burp.py", line 9 in <module>
burp = pygame.mixer.Sound("burp.wav")
pygame.error:Unable to open file 'burp.wav'
I did all the steps, I have double and tripple checked the code I entered in for mistakes. Any ideas would be appreciated.
-Jacque
topguy
Re: Burping Jelly Baby
Tue Sep 05, 2017 7:04 pm
When in doubt, use full path to the file you are trying to open.
Where is the burp.wav file located ?
Then use "/home/pi/where/burp.wav" instead of just "burp.wav".
( "/home/pi" can also be replaced with "~/" so "~/where/burp.wav" is also a posibility )
EDIT:
Did you do the "sound of a burp" step in the guide ?
If so then I guess "~/jellybaby/burp.wav" should work, but you can verify with the command "ls -l ~/jellybaby", is should then list "burp.wav".
B.Goode
Tue Sep 05, 2017 7:19 pm
I think there may be an unforeseen error in the instructions in the tutorial.
The burp.wav file should be in the directory (folder) /home/pi/jellybaby .
Your burp.py script will have been created in /home/pi/ .
@topguy seems to have come to the same conclusion.
This can be 'repaired' in one of several ways:
. Copy the script into the jellybaby directory with the sound file.
. Copy the sound file into your top level directory with the script
. Use the whole path to the sound file in the script
B.Goode
Tue Sep 05, 2017 8:30 pm
Raised as an Issue on the Raspberry Pi Foundation github repository for this resource.
https://github.com/raspberrypilearning/ ... /issues/23]
Return to “Teaching and learning resources”
Who is online
Users browsing this forum: No registered users and 2 guests
