DanielBarker
Clone multiple SD cards
Mon Oct 20, 2014 12:39 pm
Could anyone point me to hardware which will automate the process of writing an image to multiple microSD cards?
I want to avoid intialising cards 'by hand' with my laptop. I would like to achieve the same effect, but with less time and energy.
If we could initialise up to 20 cards at once, just by pushing a button or typing a command, that would be ideal.
I read somewhere that such machines start at about 500 pounds. But, I have not been able to actually locate any for sale. Partly, this may be because I don't know what they're actually CALLED. (SD card Printers? Writers? Cloners? I'm not sure.)
Thank you in advance,
Daniel Barker http://biology.st-andrews.ac.uk/staff/db60
Re: Clone multiple SD cards
Mon Oct 20, 2014 12:49 pm
This is a doctor free zone.
Gbaman
Tue Oct 21, 2014 10:04 pm
As @Dougie has pointed out, they are usually stupidly expensive.
There is nothing stopping you buying a few USB SD card read/writers to speed things up a little.
If you are fed up with SD card cloning for Pis, you might find Raspi-LTSP useful? http://pi-ltsp.net/
Lead developer of PiNet, a free and opensource centralised user accounts and file storage system for Raspberry Pi classrooms used in over 200 schools across the world.
http://pinet.org.uk
Muhsan12
Tue Nov 11, 2014 10:24 am
________________
ahsan
ghans
Tue Nov 11, 2014 3:39 pm
Buy several USB hubs and SDHC compatible SD card readers. Install Linux on your machine. Install dclfdd. Write to several cards at once (the more hubs /readers you use the slower it might get ).
ghans
RomanB
Sun Jan 18, 2015 12:12 pm
This can be helpful, if you're on Windows https://github.com/RomanBelkov/DiskImager/releases.
This is a utility I found on GitHub and added ability to write on multiple SD. I've managed to write 1.5 GB firmware (pure .img) to 4 SD cards inserted in one hub in 5 minutes
morphy_richards
Wed Jan 21, 2015 4:55 pm
Ghans put me on to dcfldd about a year ago. As he says, a couple of multiport USB hubs and some cheap sd to USB converters works really well.
I regularly use it to clone class sets in batches of 8 at a time.
Return to “Staffroom, classroom and projects”
