thedarkknight228
Raspberry Pi and Door Sensor
Thu Oct 24, 2013 12:34 pm
Hi all,
I just wanted to ask a question to see if this was possible. I am attaching a door sensor to a door which will be wired to a raspberry pi. I need the Pi to send data to my database every time the door opens. Is this possible to do?
If so does anyone know what type of information is triggered in the Pi when the door is opened?
Thanks in advance.
ZacharyI123
Re: Raspberry Pi and Door Sensor
Thu Oct 24, 2013 7:39 pm
thedarkknight228 wrote:Hi all,
Thanks in advance.
Can you tell us more about your door switch? Is it a simple reed switch? How have you connected it? Straight to the GPIO?
If so, you will need to keep checking the state of the reed switch. When you detect that the state is not the same as the last time you checked, the door has clearly opened or closed, and you can do what you want in code.
Don't be mean, I'm only thirteen 8-)
kghunt
Thu Oct 24, 2013 7:51 pm
Use an interrupt instead of constant checking.
beardedgeek
Mon Dec 02, 2013 11:19 pm
kghunt wrote:Use an interrupt instead of constant checking.
How would you do it this way rather than constantly checking?
ZacharyI123
Tue Dec 03, 2013 7:36 am
You probably want to use the built in GPIO interrupt of the RPi.GPIO framework: http://pythonhosted.org/RPIO/rpio_py.html
williamhbell
Fri Dec 27, 2013 8:47 am
In case it is useful, try looking at:
http://www.raspberrypi.org/forum/viewto ... 90#p475190
The logic needs to be flipped if you're interested in checking when the door is opened.
Regards,
Will
Piminiuser
Wed Jan 08, 2014 8:36 pm
I used wiringpi with command gpio wfi 4 rising (gpio 4) to check if it's up or down. For my doorbell project: http://raspberrypihelp.net/tutorials/38 ... e-doorbell
Return to “Staffroom, classroom and projects”
