Fri Feb 24, 2012 5:20 am
Here is the completed systems list for the Auto-Board/Vehicle Network Educator Board.
Power
Mains DC adapter (better off with a Modded PC power supply) (12v) – for testing circuits and <12v motors.
10-14v battery (12v) – for generic circuits.
(EV/hybrid) 12-100v battery(s) – for motor outputs.
(optional) Fuel cell – for battery charging and direct output to circuits/motors.
(optional) Alternator – for internal combustion engine battery charging.
Charging controller circuits and current/voltage sensors
Communication busses
CAN (central/controller area network) uses protocols similar to I2C or SPI (timed CAN bus) LIN (local interconnect network) uses UART single-wire protocol. (suppliments CAN for less important systems)
Ethernet (future vehicle bus, they should have used this in the first place!)
Inputs
(EV/hybrid) Motors x2/x4 (speed, torque, temp, current, voltage)
*Engine Management Unit (oxygen/lambda sensors, intake-mass/airflow/temp/oxygen/moisture sensors, coolent/oil temps/pressures/Res. level, crank/cam sensors, injector pressure/voltage/current, ignition detection/voltage/current, knock sensor, turbo- boost pressure/temp/oil pressure/compressor speed)
*Visual display (front/rear/side cameras)
*Aerodynamics (speed sensor, air pressure/density/mass sensors, pitch sensor) *Suspension (damper/shock absorber/spring travel sensor, angle sensors, ride height sensors)
*Lights and indication (outside light sensor, brake pedal switch, signal switches, reverse switch/sensor, interior light sensor)
*Windows (motor switches, heater switches, arial, electronic dimming-localised sun blocker sensors, HUD-interior light sensor)
*Drivetrain and Transmission (gear selection switches, clutch switch, differential- torque sensors)
*Seating (motor/vibe/heat switches, motor/vibe/heat sensors, mass sensor)
*SRS (damage sensing, occupent mass, de-acceleration)
*Steering (steering wheel position sensor/switch, yaw sensor)
*Accelerator (pedal sensor/switch, acceleration sensor, kick-down)
*Braking (pedal sensor/switch, de-acceleration sensor, wheel speed, temperature, moisture, parking brake, pressure sensors)
*Security and safety (volumetric sensing, current/voltage sensing, motion sensing, key receiver)
*GPS + Tracking (satellite receiver, VTV input signal, white line detector)
*Communication (2/3/4G, wifi)
*Media center (storage, CD/DVD/BR drive, A/D radio)
*Audio (microphones)
*OBD (signal input)
*Air-con (temperatures, speeds, flows, area selector, refrigerent pressure, heater voltage/current)
*Wipers (Moisture, speed sensor, blade wear. Screenwash-level, composition and pressure)
*Wheels and Tyres (speed, Tyre pressure, surface sensing)
Cruise and Auto-Drive control switches
Fuel pump pressure
Horn button
Embedded/Processes
(EV/hybrid) Motor relay controls
*Engine Management Unit (oxygen ?, intake/exhaust/ratio calculations, ignition/injection timing/controls, boost calculation/controls, engine/Turbo fault diagnostics)
*Visual display (camera controls, HUD controls, dials-readout control/adjustment, "other" vehicle visualisation controls, blind spot/cornering system)
*Aerodynamics (servo controls, solenoid controls, downforce/drag/drift/draft calculations)
*Suspension (damper/shock absorber magnetic stiffener control, angle adjustment control, ride height adjustment control)
*Lights and indication (headlight motion/intencity control, brake light control, signal control, reversing light control, interior light control)
*Windows (motor controls, heater controls, electronic dimming-localised sun blocker control, HUD- adjustment controls)
*Drivetrain and Transmission (gear selection control, clutch control, differential/power distribution control)
*Seating (motor control/vibe control-whiteline/heat control)
*SRS (airbag deployment control, seatbelt pre-tension control, crash severity detection, vehicle operation interrupts, mass-force calculation)
*Braking, accelerating and Steering (anti-lock braking, traction control, brake force distribution, stability control, dynamic drift control, cruise control)
*Security and Safety (Immobilizer, fuel pump shut-off, alarm activation, tracker activation and controller, lock operation, key recognition, recording/black-box operation)
*GPS + Tracking (satellite navigation, dead reckoning, VTV perception, white-line indication-seat vibe)
*Phone/Communication (services communication, signal strength, hotspot locator, auto connection)
*Media center (mostly audio)
*OBD (vehicle data logging, fault codes-read/store/erase/code list, device/reader detection)
*Air-con (temp control, flow control, section control, presets, pump control)
*Stop-start system (fuel-saver)
*Wipers (speed control, home position reset, moisture sensitivity-for speed control, screenwash pump control)
Outputs
(EV/hybrid) Motors (3-100v) x2/x4 (EV/hybrid) Motor relays x2/x4
*Engine Management Unit (ignition, injection, glowplugs, fan, coolant pump, camshafts-V.V.T, intake-throttle actuator, idle stepper motor, Ex Gas solenoid, manifold heater, Turbocharger-wastegate and variable boost solenoids, oil pump, motor output)
*Visual display (camera views, HUD, dials, readouts, "other" vehicle)
*Aerodynamics (servos, solenoids)
*Suspension (damper/shock absorber magnetic stiffener, angle adjusters, ride height adjusters)
*Lights and indication (day-lights, headlights, brake lights, signals, reversing lights, interior lights)
*Windows (including motors, heaters, electronic dimming-localised sun blocker, HUD)
*Drivetrain and Transmission (gears, clutch, differential)
*Seating (motor/vibe/heat)
*SRS (air-bags, pre-tensioners)
*Steering (servo)
*Braking (callipers-varable solenoids, electro-magnets, hydrallic pump, air pump, valves)
*Security (locks/siren/tracker)
*GPS + tracking (VTV output signal)
*Audio (amp, loudspeakers)
*OBD (diagnostic/readout)
*Air-con (blowers, heating elements, coolant pump)
*Wipers (motors, screen-wash pump)
Starter
?Wheel and tyre
Fuel pump
Horn
* = multiple sub-systems, thus more work is needed.
http://www.themagpi.com <---- Checkout the MagPi
(The MagPi - Co-Founder)
