I have just had a thought...
I have not seen a r-pi used on a portable 14" (ish) crt tv in composite mode yet?
if developing countries are going to learn to program, are they not most likely going to be using old portable crt tv's and connecting it to the composite output of the pi?. Can you imagine trying to use for example the python gui on a fuzzy composite tv! the old c64/speccy etc were limited to around 256x192 pixel displays and 32x24 characters due to this inherent composite video smear picture problem(and the width of the phosphor lines on the tube)...yes, higher res screen modes were available but the text was then totally un-readable. im also a bit worried about the linux distro resolution on the pi (both in native text and x desktop) if thats going to be a readable res on a small composite crt tv... has anyone on the pi dev team connected the pi to a old portable tv and is the linux gui readable? + is the composite output pal I, pab b, pal g, pal n, pal m, ntsc, ntsc-m, ntsc4.43, secam, 50hz,60hz or another flavour, or combination of above?
