WV2
How to share every PC monitor in class of 20 students
Sat May 25, 2019 3:29 pm
Hi
I teach Arduino in a clasroom with 20 PC's.
From September we like to offer raspberryPi courses too in the same class room.
I wonder now how to use the 20 PC's, keyboards, mouses, network for also 20 PI3's.
I want to use both GUI and non GUI control of the PI's. ( so not only putty )
Should I install tightvncserver on every PI3 and connect from every PC to a specific PI3?
Or are there better ways?
Thanks for your advise!
WV
klricks
Re: How to share every PC monitor in class of 20 students
Sat May 25, 2019 10:26 pm
The Raspbian OS has RealVNC pre installed. Much better than tightvnc XRDP etc.
RealVNC shows the actual local desktop.
You only need to enable VNC on each RPi and install the RealVNC viewer on each PC: https://www.realvnc.com/en/connect/download/viewer/
Note you do not need to sign up for the optional Connect feature in order to use the RealVNC viewer on a local network.
Andyroo
Sat May 25, 2019 10:59 pm
It would be worth checking the licence T&Cs at https://static.realvnc.com/media/docume ... spi_en.pdf
The Pi page is a bit lacking in the education area:
With VNC® Connect, you can establish direct and cloud connections, free for non-commercial use.
For use as part of a product or service, get in touch.
The other problem with VNC is that there is nothing to stop the students linking to another Pi in view mode and copying work between them or messing around with the connection settings...
I would go for a simple video / keyboard / mouse switch between the two devices :lol:
Return to “Staffroom, classroom and projects”
