brookhouser
Button controlled effects with picam
Thu Jan 18, 2018 5:02 pm
Hey all! I am working with some students to create a camera display that triggers effects on the push of a few buttons. I can get the preview to work with effects using the raspberrypi.org getting started with picam tutorial. I can also get the button to trigger the preview using the gpiozero documentation. I cannot get the button to trigger an effect by attempting to combine the two.
Here is the code that isn't working.
from gpiozero import Button
from picamera import PiCamera
from time import sleep
left_button = Button(3)
camera = PiCamera()
camera.start_preview()
left_button.when_pressed = camera.image_effect = 'colorswap'
sleep(10)
camera.stop_preview()
I assume there is a problem with line 7 using two equal signs. Anyone see a fix for me?
THanks,
Kevin Brookhouser
brookhouser
Re: Button controlled effects with picam
Thu Jan 18, 2018 5:35 pm
File this under, "let's wait and see if he figures this out on his own."
This code seems to work exactly how I want.
negativeButton = Button(2)
resetButton = Button(3)
sketchButton = Button(4)
camera = PiCamera()
while True:
    if sketchButton.is_pressed:
        camera.image_effect = 'sketch'
        sleep(5)
    elif negativeButton.is_pressed:
        camera.image_effect = 'negative'
        sleep(5)
    elif resetButton.is_pressed:
    else:
        camera.image_effect = 'none'
Return to “Staffroom, classroom and projects”
