cmazzoli
Pi desktop version does not have minecraft?
Tue Oct 10, 2017 2:37 pm
Hello!
I wanted to use the desktop version alongside the oracle virtualbox for my students to practice coding in minecraft, but after installing it i noticed that it is not there. I tried to install it and got the ./minecraft-pi: cannot execute binary file: exec format error.
anyway I can get this to work? Ideas?
thank you!
B.Goode
Re: Pi desktop version does not have minecraft?
Tue Oct 10, 2017 2:41 pm
Could you be clear about what hardware you are basing this on, and precisely which Operating System you have installed?
ShiftPlusOne
Tue Oct 10, 2017 2:46 pm
cmazzoli
Tue Oct 10, 2017 2:55 pm
ok then, i thought since it was a vr install that i would be able to do so.
Tue Oct 10, 2017 6:02 pm
You would need to run ARMHF Radpbian Stretch with Desktop in a virtual machine like QEMU.
Virtual Machine emulates x86 CPU on a machine with x86 CPU...
......the RPF Debian Jessie with Desktop is for x86 CPU.
Adieu
mikerr
Wed Oct 11, 2017 8:18 am
minecraft-pi uses the GPU so will only run on a physical Pi
QEMU emulation will only emulate the ARM CPU not the GPU, so even that is a no go (I tried it)
It IS however possible to use the minecraft-pi API on a PC, using a plugin for PC Minecraft :
http://dev.bukkit.org/bukkit-plugins/raspberryjuice/
cmazzoli
Wed Oct 11, 2017 11:37 am
got it thanks!
Return to “Staffroom, classroom and projects”
