dwcsjca
RACHEL-Pi USB installer
Thu Feb 16, 2017 12:59 am
Hi, we're working with World Possible to support RACHEL-Pi in our products (WDLabs). We have experimental software based on the NOOBS OS installer that will install the RACHEL-Pi WiFi server onto a USB drive attached to R-Pi. It's set up as a dual-boot solution: (1) boot Raspbian to provide easy setup of WiFi and enable simple selection and download of RACHEL modules (just drag 'n' drop rsync commands from the RACHEL module repository, dev.worldpossible.org/cgi/rachelmods.pl, to the terminal) and (2) boot RACHEL-Pi to serve the downloaded RACHEL modules to local clients via direct WiFi. The modules are stored in the NOOBS "Data Partition" which is shared between Raspbian and RACHEL-Pi and is maximized to the available space on the drive. The software is delivered via 2.3GB zip file for the SDcard. The USB drive doesn't require preparation. After installation the SDcard is only used for the initial boot process (and for software reinstallation) and the USB drive handles the rest.
There's a PDF at the link below with instructions, link to zip file and link to a quickie video stepping through software installation and use of server/client. This should be considered experimental, though I've been working with it on various devices with no issues (e.g. Pi3, CM3, PiDrive 314/250/375, PiDrive 64GB Flash, etc.).
https://www.dropbox.com/s/pfly5lec9gm46 ... 4.pdf?dl=0
If anyone's interested, we'd like to do field testing and would provide beta test kits.
Thanks,
Dave Chew, WDLabs
DaveOgles
Re: RACHEL-Pi USB installer
Thu Mar 09, 2017 8:13 am
Sounds ideal to me. I teach in the Highlands of Papua New Guinea. I have set up some old computers in the library for students to access the internet and some CBT resources and encyclopedias. My problem is getting the librarian to provide access for the students. A wireless system where they could connect to a WiFi access point and browse the curated resources for free would be very useful to my students.
How do I contact you to discuss becoming a beta-tester?
Dave Ogles
Scuttman
Thu Aug 03, 2017 8:49 pm
Hi Dave,
I live in Malawi and am planning on a ten location pilot using the Rachel Pi USB installer. Would you be interested in supporting this and using it as one of your Beta testing locations? We would be interested in working with you on this.
Thanks,
Chris Scutt
Wilson Drake
Fri Aug 11, 2017 7:57 am
Rachel PI USB is very much integrate-able with PI. However could it be used with some IoT devices too ?
Return to “Staffroom, classroom and projects”
