History of the Pi
Posted: Mon Nov 14, 2016 10:21 am
by mattd2989
Good morning everyone. I am currently doing a project in college which will be implementing the RPi and Lego Mindstorm to hopefully create something interesting. For my theory I need to write about the history of the Raspberry Pi. There is an abundance of information on wikipedia which I'm pretty sure is accurate. However, I can't reference inforamtion form Wiki as it's not a reliable source.
So, my question is where can I go to find legitimate information about the birth of this technology? As i cant find it on this site.
Thanks.
Matt.
Re: History of the Pi
Posted: Mon Nov 14, 2016 11:03 am
by B.Goode
mattd2989 wrote: So, my question is where can I go to find legitimate information about the birth of this technology? As i cant find it on this site.
Really?
https://www.raspberrypi.org/about/
Posted: Mon Nov 14, 2016 11:04 am
by RaTTuS
Posted: Mon Nov 14, 2016 11:17 am
by mattd2989
Really?
Yes really... I'm not sure whether you read the description properly or I wrote it poorly but I'm looking for the History of the Pi not what it is and what it does.
Posted: Mon Nov 14, 2016 11:53 am
by PeterO
mattd2989 wrote:Yes really... I'm not sure whether you read the description properly or I wrote it poorly but I'm looking for the History of the Pi not what it is and what it does.
Did you look in the Foundation's annual reports on that page ?
PeterO
Posted: Mon Nov 14, 2016 1:03 pm
by fruitoftheloom
Eben Upton - The Story of Raspberry Pi
https://www.youtube.com/watch?v=UCt6d0SCxO4
Eben Upton, founder of the Raspberry Pi Foundation, talks about the Raspberry Pi, how it came to be and the ups and downs of bringing his £25 computer to market.
Posted: Mon Nov 14, 2016 4:14 pm
by W. H. Heydt
mattd2989 wrote:However, I can't reference inforamtion form Wiki as it's not a reliable source.
Wikipedia generally includes citations to source documents. While you can't use Wikipedia itself (a secondary or tertiary source), surely you can use the references it provides.for sufficiently authoritative information or by seeing what is referenced in those links to get back to original sources. Of course, you may find that actual original sources aren't on line at all and you'll have to get "dead tree" materials to cite.
Posted: Mon Nov 14, 2016 7:21 pm
by mattd2989
Thanks for the help everyone you've really helped me out :)
Posted: Mon Nov 28, 2016 3:56 am
by MrMoke
I'm guessing your college has issues about 'free editing' on Wikipedia, when you say Wiki? No problem, go to the references, further info and external links sections of the Raspberry pi Wiki page then verify them all yourself. Remember for college papers you're not verifying the original author, you are simply quoting them and referencing them in your bibliography, you should probably get a Pi and check out that at least some of the technical quotes are accurate to lend credibility to your quotes. This sounds difficult and a lot of work, I know; but then that's what college degrees were back in the days before the internet when you had to go and sit in a library and sift through books to find the information you needed rather than having google do it for you, don't be a part of the 'spoiled' generation.
Good luck with your studies.
Posted: Thu Feb 16, 2017 4:41 pm
by seeoh9
fruitoftheloom wrote:Eben Upton - The Story of Raspberry Pi
This was very interesting, thanks @fruitoftheloom! :D
Posted: Wed Mar 08, 2017 11:39 am
by sarahgad
Good luck with the work, hope you achieve your goal.
