dier02
Blocking access to games
Thu Oct 12, 2017 10:11 pm
I want to block student access to games but not remove the games. How could I do this? Could I remove the games tab from the main menu? or is there another way of doing this?
Imperf3kt
Re: Blocking access to games
Fri Oct 13, 2017 12:23 am
Give them a new user and don't give that user permission to execute the games?
Note: I am a Windows guy, so while I know this works on Linux, I couldn't tell you how.
Current project: Handheld gaming / coding system.
Progress: Prototype complete, but has a tendency to burn the user.
Additional cooling required.
Fri Oct 13, 2017 10:08 am
The easiest way is sudo apt-get purge somenameofsomepackagethatincludesthegamesgoeshere. That will remove the menu items in the process of un-installing the game.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
B.Goode
Fri Oct 13, 2017 12:01 pm
OP asked:
@dier02 - what age and level of ability are the students concerned? Have you modified the login/authentication arrangements from standard Raspbian? Because if you don't remove the games they are likely to find and run them. And even if you remove them they could reinstall them. What is your real aim here?
Return to “Using Raspberry Pi in the classroom”
Who is online
Users browsing this forum: No registered users and 2 guests
