bstanard
setting ip addresses ahead of time for TightVNC
Thu Mar 16, 2017 1:46 pm
I am setting up for a two week training for a group of 15 middle school students by "burning" Raspian images on micro-SD cards. They will be accessing their Pi's via Ethernet cables and TightVNC clients running on either Windows laptop or desktop machines. How do I configure (and therefore know) the ip addresses of the Pi's ahead of time so that the students can log in to the Pixel desktop? I have already enabled the Pi's to boot to the GUI desktop in the image that I am using as a master for the multiple burns (using Win32DiskImage). We are using the most recent Pi 3's for the classes. Visit us at http://techlabstl.org/what-we-teach.html
RaTTuS
Re: setting ip addresses ahead of time for TightVNC
Thu Mar 16, 2017 1:48 pm
if they are all on a network then use the dhcp server to issue leases ....
Covfefe
mattmiller
Thu Mar 16, 2017 3:09 pm
This looks like valid infor
https://www.modmypi.com/blog/how-to-giv ... ess-update
try it on one and make sure it works
Alternatively, if on a DHCP network (As most schoosl are) you could probably not have to bother with this and just change the hostname of each machine and then simply use the hostname when connecting using VNC
Whatever method you use - test it beforehand :)
bstanard
Thu Mar 16, 2017 6:35 pm
Does that mean that I should log on to each micro-SD card (inserted and booted in a Pi) and give it a hostname (e.g., weasel, stoat, mole, toad, et cetera)? Otherwise, each student will have to boot when connected to a monitor, keyboard, and mouse, and connect to the DHCP served network in order to receive an ip address. Without knowing either an ip address or a hostname, the student will be unable to, upon their first login, access the Pi via a TightVNC client running on a PC. Do I have this correct, or am I missing something?
mattmiller
Thu Mar 16, 2017 7:52 pm
No - that's the situation :(
Thu Mar 16, 2017 8:10 pm
bstanard wrote:I am setting up for a two week training for a group of 15 middle school students by "burning" Raspian images on micro-SD cards. They will be accessing their Pi's via Ethernet cables and TightVNC clients running on either Windows laptop or desktop machines. How do I configure (and therefore know) the ip addresses of the Pi's ahead of time so that the students can log in to the Pixel desktop? I have already enabled the Pi's to boot to the GUI desktop in the image that I am using as a master for the multiple burns (using Win32DiskImage). We are using the most recent Pi 3's for the classes. Visit us at http://techlabstl.org/what-we-teach.html
PiNet: http://pinet.org.uk
""understanding the theoretical, but not always the end goal""
My other Devices are the ChromeBit CS10, ChromeCast & Huawei Mate 10 Pro SmartPhone
bstanard
Thu Mar 16, 2017 8:45 pm
fruitoftheloom: very cool idea, your pinet....
I'm not familiar with login using just the hostname (and not the ip address) using VNC. Can you point me in the right direction to enable this? When trying it via TightVNC, I get the following error: The requested name is valid, but no data of the requested type was found.
I am able to log in using the ip address, however.
mattmiller
Fri Mar 17, 2017 6:44 am
Sometimes, machine hostnames don't resolve but if your append .local to the the hostname you may have better success e.g weasel.local - if not then just stick to using the IPs
ghp
Sat Apr 22, 2017 4:00 pm
Hello, if you use your own Pi and own network, then a dedicated DHCP server - on a Pi - could be a solution. Assign ip addresses and node names based on mac address.
Hope this helps,
Gerhard
Return to “Using Raspberry Pi in the classroom”
Who is online
Users browsing this forum: No registered users and 2 guests
