EmmaStaves
AllseeingPi
Wed Apr 12, 2017 9:48 am
I thought that it would be good fun to create this with some girls at school but I keep having problems with out of date code etc.
When I run the code the latest problem is that it is unable to locate the PIL?
Can anyone help?
Emma
ben_nuttall
Re: AllseeingPi
Wed Apr 12, 2017 1:28 pm
It could be one of several things. If you can answer the following questions I'll do what I can to identify the problem.
- Which version of Python are you using? (2 or 3)
- Are you using Raspbian Jessie? (from raspberrypi.org/downloads)
- Has your SD been kept card up-to-date? (regular/recent apt-get update/upgrade)
Community Manager - Raspberry Pi Foundation
Author of GPIO Zero
PiGraham
Re: AllseeingPi
Wed Apr 12, 2017 1:41 pm
Did you follow the software installation step?
https://www.raspberrypi.org/learning/th ... /software/
sudo apt-get install -y python3-picamera python3-pip
sudo pip3 install guizero
sudo pip3 install twython
sudo apt-get install -y python-PIL
There is PIL
ben_nuttall
Re: AllseeingPi
Wed Apr 12, 2017 3:03 pm
I think that's the issue - you'll need the Python 3 version of PIL. The package is "python3-pil" not "python-pil".
Author of GPIO Zero
Colch
Re: AllseeingPi
Sat Jul 15, 2017 5:32 pm
Hi Ben, I hope you can help. I am also having problems with PIL.
The first two lines of code are:
import tkinter as tk
from PIL import ImageTk, Image
The error message is:
File "/home/pi/Camera/new_3.py", line 2, in <module>
ImportError: cannot import name 'ImageTk'
PIL does seem to be correctly installed:
[email protected]:~ $ sudo apt-get install -y python3-picamera python3-pip
Reading package lists... Done
Building dependency tree
python3-pip is already the newest version.
python3-picamera is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 103 not upgraded.
[email protected]:~ $ sudo pip3 install guizero
Downloading/unpacking guizero
  Downloading guizero-0.3.3-py3-none-any.whl
Installing collected packages: guizero
Successfully installed guizero
Cleaning up...
[email protected]:~ $ sudo pip3 install twython
Requirement already satisfied (use --upgrade to upgrade): twython in /usr/lib/python3/dist-packages
Cleaning up...
[email protected]:~ $ sudo apt-get install -y python3-PIL
python3-pil is already the newest version.
Return to “Staffroom, classroom and projects”
Who is online
Users browsing this forum: No registered users and 1 guest
