Neil Johnson
USB Ethernet adapters
Mon Jun 18, 2012 4:25 pm
I would like to add a 2nd Ethernet adapter to my RPi via USB.
Has anybody got any suggestions of known working ones?
I've looked @ http://elinux.org/RPi_VerifiedPeriphera ... t_adapters
And the section is empty :(
Thanks...
blurp
Re: USB Ethernet adapters
Fri Jun 22, 2012 10:07 am
i tried the "Wintech USB 2.0 LanCard Model: LAU-15 (CK0049C) successful.
They are working with the mcs7830 driver.
I dont know if the (unmodified) RPi can provide enough power.
On my RPi i shortened both USB-fuses and use an unfused separate power supply/input (5V 1,5A).
Good luck, and
Best Regards
Neil Johnson
Mon Jun 25, 2012 10:23 am
Thanks for the suggestion. I'll look in to it.
Cheers...
mrraspberrypi
Tue Sep 25, 2012 2:43 am
Just bought a Pluscom usb to ethernet adapter off ebay (item id: 220708690400). Plugged it in and red light is on. Ifconfig shows eth1 and eth0 in the terminal window. But no data being transmitted (dont know if this info helps but shows status '....RUNNING MULTICAST...'). How can I trouble shoot this? Do I need a specific driver using apt-get?
mrraspberrypi
Sat Sep 29, 2012 11:03 am
ok so my quest to build a traffic shaper (using wondershaper) resulted in me having to enable the dhcp and stuff, so from command prompt:
leafpad /etc/networks/interfaces
then added these lines to the file, saved and rebooted:
allow-hotplug eth1
iface eth1 inet dhcp
now i can ping the router and get a response but getting 'DNS can't resolve' error message from a browser
mrraspberrypi
Sat Sep 29, 2012 12:12 pm
all working with dhcp on all interfaces....
sudo leafpad /etc/network/interfaces -->
auto lo
auto eth0
auto eth1
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug eth0
allow-hotplug eth1
allow-hotplug wlan0
iface wlan0 inet manual
wpa- roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
once saved then restart your interfaces like this -->
sudo /etc/init.d/networking restart
Return to “Recommended peripherals”
Who is online
Users browsing this forum: No registered users and 6 guests
