Frabjous
Printer setup
Sat Jul 26, 2014 3:20 pm
I am installing and setting up a Samsung Xpress M2020W printer. I have installed Samsung's Linux software and SANE and its required supporting files using Synaptic. As far as I can tell, to this point, installation was successful. (I know nearly zero about anything Linux. I did read Terminal's comments, though.)
Samsung's final instructions are: ...launch printing utility (system>administrator>printing) or execute "system-config-printer" in Terminal.
Problem: I can't locate System>administrator>printing. And when I open Terminal, it doesn't recognize the system-config-printer command.
Help!
Re: Printer setup
Sat Jul 26, 2014 5:45 pm
Is the Samsung software compatable with the Pi's ARMHF architecture ? Can you post a download link ?
Printers are usually configured thru CUPS
http://www.penguintutor.com/linux/printing-cups
""understanding the theoretical, but not always the end goal""
My other Devices are the ChromeBit CS10, ChromeCast & Huawei Mate 10 Pro SmartPhone
mad-hatter
Re: Printer setup
Sat Jul 26, 2014 6:56 pm
In an LXTerminal :-
sudo apt-get install system-config-printer
You will get a menu entry in Preferences/Printing.
I'm not sure, you may need to install 'cups' and some of its related programs.
I don't know if there is a Pi driver for this printer.
Regards
Re: Printer setup
Sat Jul 26, 2014 7:15 pm
mad-hatter wrote:Hello,
In an LXTerminal :-
Regards
FYI no such thing as a Pi Driver, it is the Operating System which has drivers compiled to be suitable for the ARMv6 architecture.. :D
Frabjous
Re: Printer setup
Sat Jul 26, 2014 9:47 pm
Minutes after my first post, I found out about CUPS and installed. It appears to support every Samsung printer in existence except for any SLs. Mine, of course, is an SL-M2020.
I just did "sudo apt-get install system-config-printer." No support there, so I tried the available search function. Search function never comes up with any result.
I manually installed the driver, but that has zero effect.
Re: Printer setup
Sat Jul 26, 2014 10:06 pm
Is this your printer is it wireless enabled model ?
http://www.samsung.com/us/business/prin ... M2020W/XAA
If it is wireless and it supports Samsung Mobile Print then use Google Cloud Print, it must be on same home network as Pi
http://www.google.co.uk/cloudprint/lear ... fo-samsung
I have a HP ePrinter which is WiFi and just print to PDF then upload PDF to the the Google Cloud Print Web Page for printing
Frabjous
Re: Printer setup
Sun Jul 27, 2014 12:44 pm
Problem partially solved:
Originally I installed the Samsung driver before I installed CUPS and did system-config-printer. So, I installed the driver again, and now my printer is detected.
Won't print, related to "/user/lib/cups/filter/rastertospl" not available: No such file or directory." It's one thing after another. Brand new printer incompatible with Raspberry. ~sigh~
Thank you for your posts.
pi_nander
Re: Printer setup
Tue Jun 16, 2015 8:30 pm
Hi guys,
As stupid as I feel now, I have to admit that I have also bought this printer (sort of, I have the M2022W) and now experience the same problem.
I can´t get it to print other then the test print through the cups printers tab.
On the test print it says the following:
SPL ERROR - Please use the proper driver
POSITION : 0X0 (0)
SYSTEM : h6fwsim/xl_op
LINE : 206
VERSION : SPL 5.73.04 06-10-2014
ERROR CODE : 11-1113
My question is, has anyone fixed the problem yet or should I start looking for the receipt?
I hope that someone can help me with this problem cause this is a really good printer for the purpose that I have in mind for it...
Re: Printer setup
Wed Jun 17, 2015 5:17 am
pi_nander wrote:Hi guys,
POSITION : 0X0 (0)
LINE : 206
As this is a Wireless Cloud Printer
http://www.samsung.com/uk/consumer/prin ... M2022W/XEU
It can be used standalone ie Wireless to your Broadband Wireless Router, the Printer can be set up without connecting to a PC
Therefore you can use Google Cloud Print which takes the pain away from trying to find drivers
https://www.google.com/cloudprint/learn
http://www.samsung.com/global/microsite ... sub01.html
You may have to install IceWeasel (Firefox) Web Browser in Raspbian to access the Goole Cloud Print web site ;)
bobstro
Re: Printer setup
Wed Jun 17, 2015 5:40 am
I have found that installing a ppd file from the manufacturer is usually sufficient to get most printers working with CUPS. I downloaded the Samsung linux drivers and extracted them. There's a healthy collection of ppds located in uld/noarch/share/ppd that might be helpful
pi_nander
Re: Printer setup
Wed Jun 17, 2015 8:27 pm
Ok first of all, thanks alot for the quick reply´s. I was already looking for another printer but now I have hope for using this one.
After having looked through the Noach/shared/PPD map I have found the exact driver needed for my printer (M2020 series).
So I deleted my former printer setting (instead of modifying it) and reinstalled it using the right PPD file.
As happy as I was about finally being able to install the right driver, I found myself disappointed when the test page wouldnt even print. It just says state: stopped and nothing else...
I do think that it is now a simple matter of configuring instead of the entire trouble of finding the right driver.
Any ideas what the problem could be?
I´ll have to add though, I am still an incredible noob with the raspberry pi, linux and coding of any form BUT eager to learn.
ps.- I tried adding a screenshot but couldnt get the size of the screenshot below 64kib without making it unreadable...
Re: Printer setup
Wed Jun 17, 2015 8:50 pm
pi_nander wrote:Ok first of all, thanks alot for the quick reply´s. I was already looking for another printer but now I have hope for using this one.
The issue is that Samsung write/compile/test etc on Linux x86 systems, do they even care about ARM drivers ? likely not a high priority as most ARM Devices are Phones/Tablets which can use Air Print/Google Cloud Print.
I personally gave up and use Google Clous Print ;)
DesktopSub
Re: Printer setup
Sat Sep 02, 2017 6:28 pm
In an LXTerminal :-
Regards
Thank You mad-hatter. This post helped me a lot.
Who is online
Users browsing this forum: Batunga, Bing [Bot], hamsterball1, Kreacher and 36 guests
