farmazon3000
[wifi][8188eu] problem with TP-Link TL-WN725N v2.0
Thu Nov 07, 2013 7:21 pm
I have problem with TP-Link TL-WN725N v2.0. I can't find any driver that works.
I've tried drivers from raspishop.pl and zhujunsan.net and raspberry-at-home.com and http://blog.pi3g.com.
and instaled it via
sudo wget http://raspberry-at-home.com/files/8188eu.ko -O /lib/modules/`uname -r`/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
sudo modprobe 8188eu
and every time I run
I get error message:
ERROR: could not insert '8188eu': Exec format error
My OS is Raspbian Wheezy instaled via NOOBS v3 and updated/upgraded.
MrEngman
Re: [wifi][8188eu] problem with TP-Link TL-WN725N v2.0
Thu Nov 07, 2013 7:37 pm
Check your version of raspbian using command uname -a. If it is 3.6.11+ look here
If you have updated and uname -a shows 3.10.18+ then you will need to revert to 3.6.11+ by restoring raspbian from NOOBS and then look at the link.
Do not run command rpi-update for the moment as it will update the kernel from 3.6.11+ to 3.10.18+. There is a problem with the driver and Linux 3.10.18+ and it won't compile properly and so can't run with 3.10.18 yet. This is being looked at.
MrEngman
MoosePi
Thu Nov 07, 2013 7:44 pm
Did you see very recent this posting ?
http://www.raspberrypi.org/phpBB3/viewt ... lit=8188eu
Pi Forum Search and Google yields answers to many questions
farmazon3000
Thu Nov 07, 2013 7:45 pm
Thanks, I'll check.
So I guess that compiling it by myself like this is also no use when I've already updated to3.10.18+?
MoosePi
Thu Nov 07, 2013 7:48 pm
Best to do a forum search first as many posts relating to 8188eu....
http://www.raspberrypi.org/phpBB3/searc ... rds=8188eu
MrEngman
Thu Nov 07, 2013 7:56 pm
Hi guys
I've tried several versions of 8188eu source code including "liwei" and "lwfinger" and they all give errors compiling which stops the driver from being loaded. lwfinger is looking at the problem but I've no idea if that will produce a fix or not yet.
lwfinger is a very heavily modified liwei or similar and apparently works for 3.12.xx. But not much good for those of use using the standard code and updating with rpi-update :(
MrEngman.
MrEngman
Thu Nov 07, 2013 8:18 pm
Just in case anyone's interested you can use rpi-update to revert back to 3.6.11+ from 3.10.18+.
The command
sudo rpi-update 8234d5148aded657760e9ecd622f324d140ae891
will set the code to the final version of 3.6.11+.
This will be version
Linux raspberrypi 3.6.11+ #557 PREEMPT Wed Oct 2 18:49:09 BST 2013 armv6l GNU/Linux
MrEngman
farmazon3000
Thu Nov 07, 2013 8:33 pm
now you're saying this :), I've already reflashed my SD card ...
anyway thanks for helping, now it works OK
MrEngman
Thu Nov 07, 2013 8:35 pm
farmazon3000 wrote:now you're saying this :), I've already reflashed my SD card ...
Sorry, anyway now you know for next time ;)
MrEngman
xmoulin
Wed Feb 05, 2014 10:23 pm
I'm over a 3.10.25+, I found the solution there:
http://www.mendrugox.net/2013/08/tp-lin ... -raspbian/
Regards
@xmoulin.
whoami
Wed Sep 03, 2014 8:49 pm
Any reason this driver isn't built into the raspberry pi already? Like other nano cards, 8188eu is popular among the hobbyists.
Wed Sep 03, 2014 9:25 pm
whoami wrote:Any reason this driver isn't built into the raspberry pi already? Like other nano cards, 8188eu is popular among the hobbyists.
Do you actually mean included in Linux Operating Systems ??? http://wireless.kernel.org/en/users/Drivers
adieu
My other Computer is an Asus CS10 ChromeBit running Chrome Operating System.
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
whoami
Wed Sep 03, 2014 9:32 pm
No in the raspberry pi kernel. This module exists in ubuntu desktop for example, but not in rasbian.
whoami
Sat Sep 06, 2014 10:13 pm
update: I managed to get this card to work by:
1. Building and installing linux kernel according to http://www.raspberrypi.org/documentatio ... uilding.md
2. Building and installing drivers from: https://github.com/lwfinger/rtl8188eu (git clone --depth 1 and then make install)
Using the following hostapd config, this wifi card works as an AP as well:
#change wlan0 to your wireless device
interface=wlan0
driver=rtl871xdrv
ssid=MY_SSID
channel=1
hw_mode=g
wme_enabled=1
ieee80211n=1
#ht_capab=[HT40+][SHORT-GI-40][DSSS_CCK-40]
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=MY_PASSWORD
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
