egorogl
USB hub for rpi 3
Fri Feb 23, 2018 7:05 am
Advise the hub to connect 10 usb modems. I have a ginzzu hub on 24 ports. I use an external power supply for 9 amperes. When you connect 5 modems, everything is fine, but I turn on the 6th, usb ports hang, the keyboard is turned off, error smsc95xx. Without the Internet, you can connect all 10 modems, nothing hangs.
topguy
Re: USB hub for rpi 3
Fri Feb 23, 2018 10:33 am
I believe it is a known limitation that has been reported before that the USB-serial driver only support a certain number of devices ( or usb-endpoints ).
I'm not sure what you mean by "without the internet".
Who is online
Users browsing this forum: No registered users and 38 guests
