leokhron
ESC/POS php print from Raspberry
Mon Nov 06, 2017 8:41 am
I'm new here. I'm testing with my raspberry pi with Raspbian.
I would like to print from web with php code. I have been reading about this and the better option would be print using ESC/POS way.
After reading a lot of information I have doubts:
To print from web in my Raspberry Is necessary to install the printer in cups server? Or ESC/POS can print directly to the printer?
Is posible to print with an USB printer?
The printer is Epson TM-20
Thanks in advance!
topguy
Re: ESC/POS php print from Raspberry
Mon Nov 06, 2017 2:17 pm
USB printers are usually setup to emulate Serialport so from an application point of view its still talking to a serialport.
Personally I think its a bit overkill to use CUPS for a TM-20 but It might work, but I dont think its necessary for getting ESCPOS.
If you find an ESCPOS library for PHP your biggest challenge might be to get the web-server to have the correct access rights to the serialport(USB).
Who is online
Users browsing this forum: Burngate, danjperron and 51 guests
