I bought TL-WN722N v2. I want to use it in monitore mode.
I heard there is a many problems, but also found a solution.
https://github.com/mfruba/kernel
When I try to compile it, after make I've got a problem like that.
pi@raspberrypi:~/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417 $ make
"NO SKRC,we will use default KSRC"
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/4.9.35-v7+/build M=/home/pi/Downloads/kernel-master/drivers/TL-WN722N_v2.0-Ralink/rtl8188EUS_linux_v4.3.0.8_13968.20150417 modules
make[1]: *** /lib/modules/4.9.35-v7+/build: No such file or directory. Stop.
Makefile:1368: recipe for target 'modules' failed
make: *** [modules] Error 2
My kernel:
uname -a
Linux raspberrypi 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
pi@rasp
