spillemw
Pi with 2 ethernet ports to create router and run PFsense
Thu Sep 07, 2017 3:03 pm
I want to try run PFsense on PI, but for that I need two RJ45 ethernet ports.
(theoretically i could do it with the WLAN and the one fixed port but i do not want to do that)
Does anyone know if there are plans to come up with a two fixed ethernet version?
If not, anyone has experience using a USB to Ethernet peripheral on Pi ?
Re: Pi with 2 ethernet ports to create router and run PFsense
Thu Sep 07, 2017 7:38 pm
Lots of people have experience of using USB network interfaces on Pis. The A, A+ and Zero do not have a wired interface, so the only way to network them is to use a USB interface (I'm talking wired, not WiFi, as I know the Zero-W has WiFi).
The only real issue is that the on-board interface is connected via USB and will have to share bandwidth with any other USB devices.
Also, try to stay away from interfaces based on the DM9601 chipset as they only support USB1.1 speeds (about 11mb/s).
Thu Sep 07, 2017 8:04 pm
pfsense does not appear to officially support the Raspberry Pis ARM platform:
https://www.pfsense.org/download/
Yes you can bridge 2 ethernet connections, though ensure the USB-Ethernet Adaptor has a Realtek or Asix Chipset...
My only "PC" is an Asus ChromeBit running ChromeOS, cloudcentric at its best !
Rockchip Quad-Core RK3288C ARM32 SoC as used in ASUS Chromebook C201 & Chromebook Flip C100PA as well as the Tinker SBC.
3 Mobile Huawei E5330 Mobile Mi-Fi
Fri Sep 08, 2017 6:19 am
No, but the source code is available for download and even though it is based on FreeBSD it is possible that it could be built for a Pi. If I had any freee time at all I would look in to this, as I do use a pfsense box at work.
AbdulkaderAlrazj
Tue Jan 02, 2018 7:29 am
- Hello : - Is it possible to run pfsense on a Raspberry PI 3 ... !? - I already installed FreeBSD 12.0 on Raspberry 3 model B , and got the following link, https://github.com/pfsense/FreeBSD-port ... aster/misc or https://github.com/pfsense , for installation pfSense but I did not know how to do , so I hope so help, I need special commands to install pfSense on Raspberry , Please reply and help , I need it so much .
Yours sincerely : AbdRzj
Return to “Recommended peripherals”
Who is online
Users browsing this forum: No registered users and 7 guests
