With the excellent new "turbo-mode" overclocking option in Raspbian, it seems that this setting is not compatible with all SD cards. Using a
Transcent SD-HC 8gb class 10 you change the setting in raspi-config and reboot, wich instantly messes up /boot/config.txt
You can check this by typing;
When the last line contains a large number of the same caracter like: @@@@@@@@@@@@@
Then you know the file(system) has been scrambled. I found out that when i use a diffrent SD card
Sandisk Extreme III 2gb the "scrambling effect does not happen, so turbo-mode work's great!
As i (for one
will be looking for a new SD card, Can the people who can use the turbo-mode without problems (please check with nano) post the brand and type of there SD card here, so we know which ones work for sure?
Thanks!
