pootle
PoE spliters - the TP-Link one is good
Tue Jul 12, 2016 1:38 pm
I've tried out a couple of splitters, the TP-Link one http://www.tp-link.com/en/products/deta ... OE10R.html and a gash one from amazon https://www.amazon.co.uk/dp/B0108TD78Y/. The TP-Link one is slightly more efficient, and supports Gigabit, as well as having switchable output voltage, and it is cheaper! Even Maplin's sell them at £10. You will need a smaaaalll adapter for the TP-Link one though to get to micro usb.
Re: PoE spliters - the TP-Link one is good
Tue Jul 12, 2016 2:16 pm
pootle wrote:I've tried out a couple of splitters, the TP-Link one http://www.tp-link.com/en/products/deta ... OE10R.html and a gash one from amazon https://www.amazon.co.uk/dp/B0108TD78Y/. The TP-Link one is slightly more efficient, and supports Gigabit, as well as having switchable output voltage, and it is cheaper! Even Maplin's sell them at £10. You will need a smaaaalll adapter for the TP-Link one though to get to micro usb.
The TPLink PoE Kit is even better value, and with the cables around £20.00
http://uk.tp-link.com/products/details/ ... OE200.html
https://flubit.com/shop/p/FLK5ZL94V
Regards various other cables see:
http://www.raspberrypioneer.com/2013/06 ... r-under-15
https://www.amazon.co.uk/dp/B009C3CJG4
https://www.amazon.co.uk/dp/B009DFCCKO
Last edited by fruitoftheloom on Thu Mar 22, 2018 8:13 am, edited 2 times in total.
Retired disgracefully.....
This at present is my daily "computer" https://www.asus.com/us/Chrome-Devices/Chromebit-CS10/
pootle
Tue Jul 12, 2016 8:51 pm
If you need the injector as well as the splitter then it's excellent value. as for getting from barrel to micro usb I think this would be better than a cable (if it will fit - it will stick out quite a way.
https://makersify.com/products/adafruit ... Gwodf38Fag
