jackokring
Contact: ICQ
That video driver GPU semi-peripheral non CPU thing
Fri Aug 10, 2012 2:10 am
What is the front side bus speed of the DRAM, and how does the RAM split work? Is it just a matter of GPU/CPU election on the first opportunity to use memory? If you used 2 times the memory, then the GPU could do the slow copy (on the CPU say so) of the eye, and the CPU could write as fast as possible without GPU cycle priority.
Cheers Jacko
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
