Regarding the Gertboard PWM code ...
I am trying to control a servo that moves between 0 and 180 degrees given a single PWM at a particular duty cycle. i.e. Edge high =~ 3ms is 180 degrees, Edge high =~ .7ms is 0 degrees. 1 PWM at 50 % duty would result in the motor moving to 90 degrees.
I used the gertboard code to familiarize myself with PWM. The trouble is, I can't send a single PWM wave. This led me to look at the BCM2835 ARM Peripherals pdf. From the documentation I gather I can send a single PWM if use the FIFO mode. I, seemingly, successfully entered FIFO mode because writing to the FIFO queue changes the PWM frequency (debugging using poor mans audio). However, I am not able to configure the chip to send a single PWM. i.e. ensuring that RPTL1 = 0 doesn't have the effect of sending a single PWM.
Any advice on how to proceed? Am I understanding the FIFO queue correctly?
- Gert van Loo
- Contact: Website
Re: PWM code
It is difficult to debug from a distance.
I have not much knowledge of servos, but I understand the signal into them is about 1KHz.
Somebody wrote a while ago that it is not so critical as the duty cycle is most important,
but it could be that the default PWM signal as used in the Gertboard example is just way to fast.
Try turning the PWM clock frequency down.
Oh, I think servos still need a continuous waveform. A single pulse will not work.
Re: PWM code
Correct, in my brief experience.Somebody wrote a while ago that it is not so critical as the duty cycle is most important,
It feels like that is an issue. How do I go about turning down the PWM clock?Try turning the PWM clock frequency down.
The servo has extra logic so that the duty cycle directly translates into a 0-180 degree position. Thus, a single PWM could potentially move the device 180 degrees.Oh, I think servos still need a continuous waveform. A single pulse will not work.
- Gert van Loo
- Contact: Website
Re: PWM code
in setup_pwm read the commentchris.meyers.fsu wrote:.....
void setup_pwm()
// Derive PWM clock direct from X-tal
// thus any system auto-slow-down-clock-to-save-power does not effect it
// The values below depends on the X-tal frequency!
PWMCLK_DIV = 0x5A000000 | (32<<12); // set pwm div to 32 (19.2/32 = 600KHz)
PWMCLK_CNTL = 0x5A000011; // Source=osc and enable
So how about:
PWMCLK_DIV = 0x5A000000 | (320<<12); // set pwm div to 320 (19.2/320= 60KHz)
You have 12 bits so the maximum is 0xFFF which gives 4688 Hz.
But then you have the PWM count limit as well so if you set that to e.g. 2047 you get a frequency of 2.2 Hz.
(Not 100% sure about the last statement, I have to check that tomorrow.)
Re: PWM code
Sorry to go digging up an ageing post but could you elaborate on that? I'm trying to better understand the PWM functionality.Gert van Loo wrote: You have 12 bits so the maximum is 0xFFF which gives 4688 Hz.
My thinking currently is for a 50% duty cycle in PWM mode with MSEN=0 (no algorithm) the frequency is going to match (more or less) the clock frequency as the bits end up evenly spread out.
I'm thinking the lowest frequency with a 50% duty cycle you could achieve is ~147 Hz with the clock at 4688 Hz in MSEN=1 mode with a range of 64 bits and serial data to transmit being 0xFFFFFFFF. So unless my thinking is wrong this should give a 32 cycles high followed by 32 cycles low wave?
If I am wrong on this could someone provide a quick explanation?
- Gert van Loo
- Contact: Website
Re: PWM code
With 50% duty cycle you will get HALF your clock frequency as the output will toggle every clock.
The 4688Hz clock is if you use the Xtal 19.2MHz as source. If you find a lower source the frequency will also be lower.
I have no idea what all the clocks are which are available during normal operation.
I have never looked into the details of the MSEN=1 mode.
Also if very low frequencies are required you can use SW running from the system timer.
Re: PWM code
Hi Gert,
So in your code it seems that the PWM frequency will change depending on the duty cycle.
Is it possible to keep the PWM frequency the same, regardless of duty cycle?
This would be a preferred implementation for many people.
Felix
Felix
- Gert van Loo
- Contact: Website
Re: PWM code
Sorry but that is not possible. A good PWM signal by definition will have a changing frequency.felixfurtak wrote:Hi Gert,
Felix
Re: PWM code
Hi Gert,
Thanks for your reply. I thought PWM had constant frequency by definition. Maybe there are some variants?
I'm not sure I understand why this would be impossible to generate, but thanks for the info.
The problem that I have is that with a changing frequency, the switching losses in my transistors will also increase as the frequency increases, which will reduce linearity of the PWM. I guess, putting a larger clock divider would help.
Thanks again
Felix.
Thanks again
Felix.
Re: PWM code
I have not tested this, but I suspect when the data sheet says "M is the data to be sent", it means the number of bits, not the actual pattern.alanb wrote:I'm thinking the lowest frequency with a 50% duty cycle you could achieve is ~147 Hz with the clock at 4688 Hz in MSEN=1 mode with a range of 64 bits and serial data to transmit being 0xFFFFFFFF. So unless my thinking is wrong this should give a 32 cycles high followed by 32 cycles low wave?
So with MSEN=0, RANGE=8, DATA=3, you get a repeating pattern 00100101, and with MSEN=1, RANGE=8, DATA=3, you get repeating 11100000. To an application that cares only about the long-term average, these are the same output level: 3/8. Incidentally, MSEN=1 is what I would call PWM, and MSEN=0 is really Pulse Density Modulation.
In both cases, the output cycle time does not vary with duty cycle, as long as you adjust the duty cycle by changing DATA only and keeping RANGE constant.
Re: PWM code
I,m with you Felix - surely the frequency is the same, but its the mark/space ratio that changes with PWM ?felixfurtak wrote:Hi Gert,
Thanks again
Felix.
Texy
Re: PWM code
Ah sorry a frequency of 1/2 makes sense, didn't think that one through properlyGert van Loo wrote:With 50% duty cycle you will get HALF your clock frequency as the output will toggle every clock.
Re: PWM code
Thanks I wasn't sure if it meant what you suggested or treat the data register as actual data to be sent "serially". Reading over the data sheet again I would be inclined to agree with you here. I think I was combining PWM mode with MSEN=1 and Serialiser mode.jojopi wrote:I have not tested this, but I suspect when the data sheet says "M is the data to be sent", it means the number of bits, not the actual pattern.alanb wrote:I'm thinking the lowest frequency with a 50% duty cycle you could achieve is ~147 Hz with the clock at 4688 Hz in MSEN=1 mode with a range of 64 bits and serial data to transmit being 0xFFFFFFFF. So unless my thinking is wrong this should give a 32 cycles high followed by 32 cycles low wave?
Cheers
Re: PWM code
I don't get it how it works with changing frequency stuff,
Can someone explain :s
