Hehe, I misread that and was going to post a picture of my GertVGA board.Matty11611 wrote:hi, yes i have followed exactly as it says on the page and tried with two add on boards, if anyone could upload a .img image with this working then i can rule out the addon board and the software side of things
It was a while back and I only assembled it to have a go and tried it out to see if it would work.Matty11611 wrote:Doug, Thanks for your response, would it be possible for you to make a copy of the os that you have running with your tv so i can try exactly the same os system image, i have 2 monitors and a tv so hopefully with a known working screen, vga board and image i can work on whittling the issue down.
Thanks again, i assume you just changed the mode and group of the dpi?
AIUI Gert's VGA adapter actually uses device tree for setup; the dt-blob.bin is a compiled device tree file; similar to the ones used in the new Pi2B kernel.BMS Doug wrote:Dirk S suggested in another thread that the latest pi install may cause problems because of device tree. I have seen posts describing how to disable device tree but I can't get this tablet to copy/paste at the moment.
Try this image https://www.dropbox.com/s/zszpjr33rc0wu ... p.zip?dl=0. It's a zipped image and IIRC it worked the last time I tried it.Matty11611 wrote:DirkS you had any luck in finding your working image yet?
Yes, I have cross compiled kernels for the A(+) and B(+) a couple of times using the instructions at http://www.raspberrypi.org/documentatio ... uilding.md.Matty11611 wrote:just another quick question, have you managed to make any kernels yet for the RPI, im struggling and just want to change the logo in the current one.
