Un4Seen
Setting up Razberry for Raspberry Pi
Thu Jan 08, 2015 7:27 pm
Hello Everybody!
I have bought a Razberry daughter card (see: http://razberry.z-wave.me/) for my Raspberry Pi in hope that I'll be able to use it as a controller for my Z-Wave devices (see: http://en.wikipedia.org/wiki/Z-Wave).
The problem is that I can't get it to work :) I'm hoping somebody here has gone through the same process and may be able to help me.
I'm using the Razberry with a Raspbery Pi model B (almost 2 years old installation, but up-to-date firmware and apt-get). I followed the installation instructions from here: http://razberry.z-wave.me/index.php?id=24
So I executed this:
wget -q -O - razberry.z-wave.me/install | sudo bash
Here is my installation log:
Linux raspberryrho 3.12.35+ #730 PREEMPT Fri Dec 19 18:31:24 GMT 2014 armv6l
[email protected] ~ $ wget -q -O - razberry.z-wave.me/install | sudo bash
Do you accept Z-Wave.Me licence agreement?
Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf
yes/no: yes
z-way-server new installation
Hit http://raspberrypi.collabora.com wheezy Release.gpg
Get:1 http://mirrordirector.raspbian.org wheezy Release.gpg [490 B]
Hit http://archive.raspberrypi.org wheezy Release.gpg
Get:2 http://mirrordirector.raspbian.org wheezy Release [14.4 kB]
Hit http://raspberrypi.collabora.com wheezy/rpi armhf Packages
Hit http://archive.raspberrypi.org wheezy/main armhf Packages
Get:3 http://mirrordirector.raspbian.org wheezy/main armhf Packages [6,893 kB]
Ign http://raspberrypi.collabora.com wheezy/rpi Translation-en_GB
Ign http://archive.raspberrypi.org wheezy/main Translation-en_GB
Hit http://mirrordirector.raspbian.org wheezy/contrib armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/non-free armhf Packages
Hit http://mirrordirector.raspbian.org wheezy/rpi armhf Packages
Ign http://mirrordirector.raspbian.org wheezy/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/main Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org wheezy/rpi Translation-en_GB
Fetched 6,908 kB in 43s (158 kB/s)
Reading package lists... Done
Removing MathKernel
Building dependency tree
Package 'wolfram-engine' is not installed, so not removed
The following packages were automatically installed and are no longer required:
  libmozjs17d xulrunner-17.0
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
Installing additional libraries for HomeKit
Building dependency tree...
The following extra packages will be installed:
  avahi-daemon libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd1 libavahi-core7 libdbus-1-dev libnss-mdns
Suggested packages:
  avahi-autoipd
The following NEW packages will be installed:
  avahi-daemon libavahi-client-dev libavahi-common-dev libavahi-compat-libdnssd-dev libavahi-compat-libdnssd1 libavahi-core7 libdbus-1-dev libnss-mdns
0 upgraded, 8 newly installed, 0 to remove and 23 not upgraded.
Need to get 692 kB of archives.
After this operation, 2,065 kB of additional disk space will be used.
Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-compat-libdnssd1 armhf 0.6.31-2 [45.1 kB]
Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-core7 armhf 0.6.31-2 [119 kB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main avahi-daemon armhf 0.6.31-2 [94.2 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-common-dev armhf 0.6.31-2 [68.5 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libdbus-1-dev armhf 1.6.8-1+deb7u5 [216 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-client-dev armhf 0.6.31-2 [62.3 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libavahi-compat-libdnssd-dev armhf 0.6.31-2 [62.8 kB]
Get:8 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libnss-mdns armhf 0.10-3.2 [23.7 kB]
Fetched 692 kB in 1s (437 kB/s)
Selecting previously unselected package libavahi-compat-libdnssd1:armhf.
(Reading database ... 71004 files and directories currently installed.)
Unpacking libavahi-compat-libdnssd1:armhf (from .../libavahi-compat-libdnssd1_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libavahi-core7:armhf.
Unpacking libavahi-core7:armhf (from .../libavahi-core7_0.6.31-2_armhf.deb) ...
Selecting previously unselected package avahi-daemon.
Unpacking avahi-daemon (from .../avahi-daemon_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libavahi-common-dev.
Unpacking libavahi-common-dev (from .../libavahi-common-dev_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libdbus-1-dev.
Unpacking libdbus-1-dev (from .../libdbus-1-dev_1.6.8-1+deb7u5_armhf.deb) ...
Selecting previously unselected package libavahi-client-dev.
Unpacking libavahi-client-dev (from .../libavahi-client-dev_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libavahi-compat-libdnssd-dev.
Unpacking libavahi-compat-libdnssd-dev (from .../libavahi-compat-libdnssd-dev_0.6.31-2_armhf.deb) ...
Selecting previously unselected package libnss-mdns.
Unpacking libnss-mdns (from .../libnss-mdns_0.10-3.2_armhf.deb) ...
Processing triggers for man-db ...
Setting up libavahi-compat-libdnssd1:armhf (0.6.31-2) ...
Setting up libavahi-core7:armhf (0.6.31-2) ...
Setting up avahi-daemon (0.6.31-2) ...
[ ok ] Reloading system message bus config...done.
[ ok ] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Setting up libavahi-common-dev (0.6.31-2) ...
Setting up libdbus-1-dev (1.6.8-1+deb7u5) ...
Setting up libavahi-client-dev (0.6.31-2) ...
Setting up libavahi-compat-libdnssd-dev (0.6.31-2) ...
Setting up libnss-mdns (0.10-3.2) ...
First installation detected...
Checking NSS setup...
Making symlinks to libssl.so
Making symlinks to libcrypto.so
Getting Z-Way for Raspberry Pi
--2015-01-08 20:57:45--  http://razberry.z-wave.me/z-way-server/z-way-server-RaspberryPiXTools-v2.0.0.tgz
Resolving razberry.z-wave.me (razberry.z-wave.me)... 46.20.244.36
Connecting to razberry.z-wave.me (razberry.z-wave.me)|46.20.244.36|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 11814368 (11M) [application/x-gzip]
Saving to: `STDOUT'
100%[================================================================================================================================>] 11,814,368  1.00M/s   in 16s
2015-01-08 20:58:01 (713 KB/s) - written to stdout [11814368/11814368]
New version z-way-server installed
Creating Z-Way startup script
Adding z-way-server to autostart
update-rc.d: using dependency based boot sequencing
--2015-01-08 20:58:03--  http://razberry.z-wave.me/webif_raspberry.tar.gz
Length: 408241 (399K) [application/x-gzip]
Saving to: `STDOUT'
100%[================================================================================================================================>] 408,241      554K/s   in 0.7s
2015-01-08 20:58:04 (554 KB/s) - written to stdout [408241/408241]
First install, getting razberry ID
--2015-01-08 20:58:04--  http://find.zwave.me/zbw_new_user
Resolving find.zwave.me (find.zwave.me)... 46.20.244.72
Connecting to find.zwave.me (find.zwave.me)|46.20.244.72|:80... connected.
Length: unspecified [application/octet-stream]
Saving to: `/tmp/zbw_connect_setup.run'
    [ <=>        ] 5,914       --.-K/s   in 0s
2015-01-08 20:58:06 (20.4 MB/s) - `/tmp/zbw_connect_setup.run' saved [5914]
Now you can run zbw_connect with /etc/init.d/zbw_connect start
or simply reboot your system
Your user id: 18697
Your password: jahh4Xohchex
[....] Starting zbw_connect:[info] ok.
bash: line 371: /etc/init.d/mongoose: No such file or directory
--2015-01-08 20:58:20--  http://razberry.z-wave.me/mongoose.pkg.rPi.tgz
Length: 44749 (44K) [application/x-gzip]
Saving to: `STDOUT'
100%[================================================================================================================================>] 44,749       280K/s   in 0.2s
2015-01-08 20:58:20 (280 KB/s) - written to stdout [44749/44749]
Adding mongoose to autostart
Start mongoose http server
ls: cannot access config/zddx/*.xml: No such file or directory
Usage: ./z-cfg-update <filename>
Preparing AMA0 interface:
 removing 'console=ttyAMA0,115200' and 'kgdboc=ttyAMA0,115200' from kernel command line (/boot/cmdline.txt)
 removing '*:*:respawn:/sbin/getty ttyAMA0' from /etc/inittab
AMA0 interface reconfigured, please restart Raspberry
Do you want to receive emails with news about RaZberry project?
! Please subscribe again if you did it before 30.03.2013
yes/no: no
Thank you for using RaZberry!
After installing, I plugged in the Razberry card, rebooted (and even power-cycled the Pi). If I go to http://find.zwave.me/zboxweb it can see my Razberry and it gave me a new ID for it.
If I go to http://192.168.1.21:8083/ (that's the local IP of my Pi which has the Razberry card on it), I can choose from the different UIs, so in a way it works.
But when I try to use the expert UI, I always get this error: "Error handling data from server"
And in the home automation UI I get these warnings: "Can not start Z-Wave binding: Error: Bad data - communication failed"
I tried to follow the known problems instructions. The LEDs on the Razberry card do blink as they should on boot, I did power-cycle the Pi, I checked the /etc/inittab and /boot/cmdline.txt files for occurences of "AMA0" and found nothing, so in theory everything should be fine...
On thing that might be worth mentioning is that I did not plug the Razberry card onto the GPIO header if my Pi as they suggest, instead I connected the 3V3, GND, RxD and TxD pins with jumper cables. Seeing that things don't work, I tried to connect the Razberry card properly (stacking it onto my Pi), but it did not help. Same erros.
Looking at the /var/log/z-way-server.log file I see some error and warning entries in it, for example:
[2015-01-08 21:03:35.187] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x00
[2015-01-08 21:03:35.827] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2015-01-08 21:03:35.828] [C] [zway] Get Serial API Capabilities returned zero.
[2015-01-08 21:03:35.998] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
Does anybody have any idea what could be wrong?
I'd normally post this to http://forum.zwave.me/, but their forum seems to have some bug and they don't accept new members (the verification code cannot be read). Perhaps if you are an existing member, can you copy this to their forum?
Thank you!
Andras
http://iqjar.com
Un4Seen
Re: Setting up Razberry for Raspberry Pi
Fri Jan 09, 2015 6:06 am
OK, figured it out myself :) I hope I can help others fix this problem, here's the solution :)
I had a script that ran at boot (called from /etc/rc.local) which initialized all GPIO pins to output mode and LOW. This is because I used this Pi in the past to drive some LEDs. I guess this messed with the TxD and RxD pins, which are used by the Razberry.
So if you encounter the following errors:
In the expert UI: "Error handling data from server"
In the home automation UI: "Can not start Z-Wave binding: Error: Bad data - communication failed"
then not only foollow this guide: http://razberry.z-wave.me/index.php?id=29
but also makes sure that nothing messes with the state of the RxD and TxD GPIO pins (GPIO14 and GPIO15)!
Andras
http://iqjar.com
Un4Seen
Wed Feb 25, 2015 6:41 am
Anybody having issues with Razberry after updateing their Pi lately?
I'm using Razberry with Domoticz on a RPI V1 model B+ and since I made a software and firmware update
sudo apt-get update
sudo apt-get upgrade
sudo rpi-update
last night, the Razberry card is not recognized anymore by Domoticz.
My last such update was about a month ago, before the Pi v2 came out (and it did not break anything), so I'm thinking maybe the new kernel has something to do with the Razberry card not working anymore.
Wondering if anybody else has this problem...
Andras
http://iqjar.com
Wed Feb 25, 2015 7:23 am
Un4Seen wrote:Anybody having issues with Razberry after updateing their Pi lately?
sudo apt-get update
sudo rpi-update
rpi-update should not be used, it is liable to break your system, you will need to undo your changes, there have been a few posts regarding this issue over the last week.
adieu
My other Computer is an Asus CS10 ChromeBit
Un4Seen
Wed Feb 25, 2015 7:25 am
What is the recommended method to update the firmware if not rpi-update?
Andras
http://iqjar.com
Wed Feb 25, 2015 7:39 am
Un4Seen wrote:What is the recommended method to update the firmware if not rpi-update?
http://www.raspberrypi.org/forums/viewt ... 8&t=101520
The stable firmware release is updated when undertake
sudo apt-get update
or
sudo apt-get update
sudo apt-get dist-upgrade
adieu
Un4Seen
Wed Feb 25, 2015 7:51 am
Wow! I did not know that. In the old days I think the firmware was not handled by apt-get.
Thanks, man!
Andras
http://iqjar.com
Un4Seen
Wed Feb 25, 2015 8:08 am
Is there any way to revert to the stable firmware without restoring a full SD card image? I do have a backup from before the rpi-update, but I'm not at home, I can only access the RPI remotely...
I know you can give a hash as an argument to rpi-update, but where can I get the hash for the latest stable firmware?
Andras
http://iqjar.com
Un4Seen
Wed Feb 25, 2015 8:23 am
Andras
http://iqjar.com
rajabatchu
Fri Mar 20, 2015 2:39 pm
Razberry Z-wave server not binding with zwave plug TKB68ZE
These are the error messages:
There are no mentions of ttyAMA0 in both /etc/inittab and /boot/cmdline.txt files.
Tried on a new raspberry pi model B+ and connected it as shown in image on http://razberry.z-wave.me/ website.
http://127.0.0.1:8084/cgi-bin/main.cgi
z-way remote access not responding after entering password.
Tried it with different versions of zwave i.e v1.4 and v2.0
Attaching the log file and screen shots FYI.
[email protected] ~ $ tail /var/log/z-way-server.log
[2014-06-20 19:17:34.653] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2014-06-20 19:17:34.857] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2014-06-20 19:17:34.857] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2014-06-20 19:17:34.857] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2014-06-20 19:17:34.858] [C] [zway] Get Serial API Capabilities returned zero.
[2014-06-20 19:17:34.858] [I] [zway] Removing job: Get controller info and supported function classes
[2014-06-20 19:17:34.868] [D] [zway] Worker thread exit point
[2014-06-20 19:17:34.869] [D] [zway] Worker thread successfully finished
[2014-06-20 19:17:34.884] [I] [core] Notification: critical (z-wave): Can not start Z-Wave binding: Error: Bad data - communication failed
[2014-06-20 19:17:41.116] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
Kindly help me to troubleshoot.
ToineFrijters
Sun Jan 10, 2016 2:23 pm
Hi
I have the same problem, did you get an answer or resolved it anyway.
Toine
eusrfel
Sat Sep 24, 2016 10:33 am
Hello!
I have exactly this problem and I do not know what to do. I have followed all above and still have the problem. Any suggestions to get around this problem?
// Robert
Luis87
Tue Jan 24, 2017 3:02 pm
Hi guys, kinda new on this topics but I just buy a new razberry HAT for the RPI 3 model B and I get this error every time I want recognized a z wave device.
"An unexpected error occurred while initialising the Z Wave controller data" and then 3 options, I just read in another forum (the z wave.me forum) that it's a trouble about with licenses of the products.
Hope you can help me out. Thanks
Luis87
Wed Jan 25, 2017 6:52 pm
I just get a tip from this site https://hallard.me/enable-serial-port-on-raspberry-pi/ it seems the trouble is the pins on the RPI 3 they are enabled in LOW usage, so this just gave me some clues on the trouble. But still figuring out
tromper
Wed Oct 11, 2017 6:53 pm
Hi, I just got the razberry and installed it on my raspberry using the command that is written in the razberry's manual. The problem is that I am not able to access to the port 8083 (192.168.0.30:8083) by typing it on my computer. Does anyone know what the problem could be?
v526
Thu Nov 02, 2017 10:55 am
Having the same problem with my razberry that I received yesterday.. Anyone having a solution?
LSD
Fri Nov 24, 2017 5:50 am
Same here, anyone finding a solution?
mouse-company
Tue Dec 19, 2017 9:35 pm
I've 2 brand new Raspberry with Razberry Z-Wave boards, both have same issue when trying to access IP:8083 or IP:8084. Chromium-Browser tells me that I do not have access and I should check firewall settings or virus scan settings. When I look up the proxy settings in Chromium, it tells me that it can't access the proxy settings or the system config could not get startet. Did completely re-instal Raspian OS and Z-Wave and still same issue. Who can help here? This seems like a general issue with newer Raspberry 3 or the provided os images.
_diegop_
Fri Jan 05, 2018 3:11 am
thanks guys , now raspberry and z wave are working !!!
thanks thanks !!!
this is my case and this is what i did , if it helps u i will be happy !!
1 i did install this noobs with wheezy NOOBS_v1_4_1 , you can find the old .zip files right in the official page. (DONT INSTALL HIGHER VERSIONS THAN NOOBS 1.4.1 )
2 port 8083 wasnt working ... it was only letters ... no html was rendered ...
3 i did install chromioum for raspberry pi and then i was able to see 8083 ... harmony browser its a terrible browser !!
4 i did use sudo sh -c "echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json"
so i was able to activate 8084 and i didnt have to update to a new version.
5 i went to 8083 then i went to expert and i was able to activate my switcher device !!!
thanks everybody !!
Max Faye-Wevle
Sun Feb 25, 2018 6:59 pm
Hi!
I have the same problem but i cant see 8083 in chromioum for raspberry pi. Do anyone have a solution?
Best regards Max
