Page 1 of 13
TinyTOSLINK (digital audio output) now for B+, too
Posted: Mon Dec 08, 2014 8:31 pm
by [IDC]Dragon
Hi there,
some people may know my "TinyTOSLINK" addon for the classic rev. B board:
http://www.raspberrypi.org/forums/viewt ... 45&t=75225
(optical audio output, optional S/PDIF output and input)
I now have created a B+ variant. It is larger, because the required pins are all over the connector. But it still is a relatively small strip of PCB, can be installed without soldering.
Logically it can be a HAT, because I added a footprint for the ID EEPROM. Mechanically it isn't, because I wanted all to fit in a normal case, no buildup for an extra board ontop. The TOSLINK transmitter is mounted downwards, to not add height. Like with my other board, it could be mounted "deep" and soldered directly to the header, the transmitter on the top side. But I guess since plugging with 40 pins is quite rigid and needs no soldering, nobody will go for that with B+.
I chose a smaller transmitter this time, to leave more room for the LEDs underneath. And it has 25 MHz bandwidth, which is needed to transmit 192 kHz sample rate audio. Until recently, I didn't know such is possible for TOSLINK, thought it would require S/PDIF. The receiver needs to be capable, too, which had a ripple effect in my household, replacing switchbox and DAC input receivers...
However, these components are hard to find, I ordered them from china.
Finally, some pictures, click them to enlarge:
I can build some of these, for people who appreciate my work and have good use for it. Before doing so, I need to find a source for the 40 pin connector with a reasonable price.
So long,
Jörg
Jörg
Re: TinyTOSLINK (digital audio output) now for B+, too
Posted: Fri Jan 02, 2015 9:19 pm
by dan.mcmullen
do you have any idea when you will have any of these made/available? Will these work with the "B" model? I will be upgrading to a "B+" soon. How much are you selling them for and can you ship to Canada?
Posted: Tue Jan 06, 2015 1:14 pm
by BMS Doug
Jörg
Hi Jörg,
I found some on Amazon, £6.85 for 10. These would also be shipped from China.
I hope this helps.
Posted: Tue Jan 13, 2015 7:36 pm
by Man in a van
Please include me for one of these.
PM sent.
atb
Ronnie.
Posted: Wed Jan 14, 2015 6:47 pm
by jnetode
Hi, Jörg,
awesome work. I am very interested on getting also one.
An alternative (although more expensive) would be to use shield stacking headers. Since the PCB will use all the 40 pin connector, there will be nothing else available for further usage.
I will also try to find something in reasonable price too.
Joel
Posted: Thu Jan 15, 2015 8:55 pm
by [IDC]Dragon
Thanks for you help about connector sources. Meanwhile I'm settled, got a batch of them for like 0.50€ each.
The kind with normal pins, so you can't stack another board on top. Joel has sent me a list of suppliers for longer pins.
Jörg
Posted: Fri Jan 16, 2015 2:32 pm
by richw2000
This is really awesome. Great work.
I've been searching all over for this type of solution.
I have a project that I could use this in.
If you have a spare, I'd be willing to buy 1 or 2.
Posted: Sat Jan 17, 2015 1:59 am
by chrismccallum
This is just what I've been looking for. Amazing. I would be very interested in getting on of these from you!
Cheers
Chris
Posted: Thu Jan 22, 2015 10:43 am
by Man in a van
Jörg,
The board arrived Wednesday last, thanks very much.
I fixed it to a pi B+ with piCorePlayer image on the SD card.
I found out that the drivers are supported in the HiFiBerry Digi for the B and B+.
For the B+ I used … sysdefault:CARD=sndrpihifiberry …as output.
Well it works, and as a bonus I found that my DAC supports 192 kHz as default.
Only caveat I have is that the pin header is a really tight fit, as in REALLY TIGHT (I bent the end pins on removing the board
What can I say?
Many thanks for sharing your project with everyone and I wish you lots of success.
atb
Ronnie.
Posted: Thu Jan 22, 2015 11:25 am
by pleasure
HI Jörg,
I popped this on my B+ and within 5 minutes openelec was streaming DTS & AC3 in 5.1 faultlessly.
What a great little addon fits so nicely in a standard case (I just left one end off for now to plug the optical into)
What can I say apart from thanks again.
Regards,
Richard
Posted: Thu Jan 22, 2015 12:53 pm
by BMS Doug
I had the same issue with a GertVGA board, I think it's unavoidable with the 40 pin header, with so many connections it will be a tight fit and easy to become frustrated when removing it. Once one end is up you are so relieved that it's moving that you keep pulling on the end that has moved and as a result you bend the pins at the other end (I think that this is what happened in my case at least).
I think that if we are patient and careful when removing the 40 pin headers we will avoid bending the pins.
Posted: Thu Jan 22, 2015 2:35 pm
by Man in a van
Exactly what happened to me
Maybe a spray with Servisol lubricant (or similar other product)?
Posted: Thu Jan 22, 2015 9:17 pm
by markusA
Ooh, I want one of these, it's exactly what I've been looking for. Is it possible to get one? I'm new to the forum and don't seem to be able to pm yet?
Posted: Sat Jan 24, 2015 8:19 am
by [IDC]Dragon
Yes, it's possible to get a board. Do some good postings until you have credibility to send me a PM.
I'm not aware of such limitation, probably it works by now, after your first post?
Jörg
Posted: Sat Jan 24, 2015 8:56 am
by markusA
Awesome, PM sent.
Posted: Thu Feb 05, 2015 12:40 am
by foresto
Jörg, this is outstanding. It fills a gap that kept me away from the Raspberry Pi for use as a media player.
Do you know whether it will work on the Raspberry Pi 2?
Posted: Thu Feb 05, 2015 6:45 am
by markusA
I just received mine and it is a beauty. Very professionally done, impressive to say the least.
In the documentation for the Pi 2 it says it's compatible with the B+ but it would be nice to hear confirmation from IRL trials.
Posted: Thu Feb 05, 2015 10:18 am
by DougieLawson
markusA wrote:I just received mine and it is a beauty. Very professionally done, impressive to say the least.
The official line I've seen is that any hardware add-on that works with a A+/B+ will work with a 2B. The board is identical to the B+ except it's got a BCM2386 chip on the top and a 1GB RAM chip on the bottom.
Posted: Thu Feb 05, 2015 10:25 am
by orsman
Hi Joerg, this looks really nice! I would love to buy a board from you. I hope I can send you an PM after I have posted this reply.
Posted: Fri Feb 06, 2015 8:57 am
by testbert
Hi Joerg,
is it using I2S or is the signal transferred by another mehtod (e.g. DA --> AD conversation)? I thought (because all other implementations do it like that) I2S has to be taken from the P5-Header.
In general your TinyTOSLINK for Raspy B+ seems to be a really great deal, in order to have a galvanic isolated digital out on the Raspi.
Regards,
Stefan
Posted: Fri Feb 06, 2015 12:15 pm
by pleasure
Hi Jörg,
I have tried this with a pi 2 using openelec 5.01.
It now has a newer kernel (3.18) that uses a device tree instead of modules.
No luck getting the card recognized yet.
I will report back if I have any success.
Regards,
Richard
Posted: Fri Feb 06, 2015 12:58 pm
by pleasure
Hi Jörg,
Great news, as expected this works perfectly with the Pi2. (on openelec 5.01)
With the new kernel the sound cards are configured in a different way.
This post explains it succinctly.
http://forum.kodi.tv/showthread.php?tid ... pid1916788
Once again, great little addon
Regards,
Richard
Posted: Fri Feb 06, 2015 5:42 pm
by [IDC]Dragon
Hi Richard, thanks for the pointer.
Today my Raspberry Pi 2 arrived, and wasn't working out of the box. My distro was freshly upgraded, but still it woudn't boot from the old card. I had to prepare a new one, used Noobs for that.
To summarize the device tree business:
As far as I understand, a device tree is a set of dependencies for drivers. It is defined by a binary file called overlay, placed into /boot. Since this is the FAT32 part of the card, it's now even possible to prepare that on the card under Windows. The overlay file is referenced in a to-be-added line in config.txt.
Overlays and some documentation can be found here, we need the file "hifiberry-digi-overlay.dtb" from it:
https://github.com/raspberrypi/firmware ... t/overlays
In config.txt you need to add a line:
dtoverlay=hifiberry-digi
It can be done live on the board as well, with e.g. the following:
sudo su
cd /boot
wget https://github.com/raspberrypi/firmware/raw/master/boot/overlays/hifiberry-digi-overlay.dtb
echo "dtoverlay=hifiberry-digi" >> config.txt
Jörg
Posted: Sun Feb 08, 2015 1:56 pm
by Macscully
Hi Jörg,
Great Work! I'm really interested in buying one. I just bought a RaspberriPi model B and the only thing it is missing is a decent sound output.
Posted: Mon Feb 09, 2015 1:39 pm
by tricky
Hi Jörg,
I am using my Pi as a home media system and was nearly scrapping my non HDMI sound amp till I read this : )
This is a great idea for the Pi.
How could I get hold of a TinyTOSHLINK board??
Cheers
Rick
