slmaws
Prototyping HAT board
Wed Nov 12, 2014 9:42 pm
Hello everyone
Can someone recommend where can I buy Raspberry Pi Prototyping HAT board?
I found some boards but all of them are not compatible with HAT.
Regards
See my Raspberry Pi tips on http://rpitips.com
mahjongg
Re: Prototyping HAT board
Wed Nov 12, 2014 11:07 pm
slmaws
Thu Nov 13, 2014 12:37 am
I know this one, but:
Not in stock, replenishment ordered.
slmaws
Thu Nov 13, 2014 12:25 pm
This are not in HAT standard. For example there is no space for camera.
Here is how it should look: https://github.com/raspberrypi/hats/blo ... anical.pdf
mahjongg
Thu Nov 13, 2014 11:08 pm
just for your information; the lack of a camera slot does NOT prevent the board from conforming to the HAT standard, as the standard allows for boards without the slot! It should have an EEPROM though, but you could in principle hand wire one in.
slmaws
Fri Nov 14, 2014 12:07 am
mahjongg wrote: just for your information; the lack of a camera slot does NOT prevent the board from conforming to the HAT standard, as the standard allows for boards without the slot! It should have an EEPROM though, but you could in principle hand wire one in.
Good to know. Thank you for explenation
TonyD
Fri Nov 14, 2014 1:11 pm
Tony
awatterott
Mon Nov 17, 2014 1:23 pm
slmaws wrote:I know this one, but:
The Prototyping HAT without EEPROM is currently out of stock, but the version with EEPROM is in stock:
http://www.watterott.com/en/RPi-Proto-HAT-ID-EEPROM
