Hey Guys,
I just setup my GertDuino with this instruction:
http://www.raspihub.com/go/763443df72d2 ... 3d282ac312
And for the avrdude I got this instruction:
https://projects.drogon.net/raspberry-p ... ega-setup/
I than startet ./avrsetup and choose 1 for the ATmega328p. It was succesful.
Afterwards I tried the blink file and it works. I also wanted to try the arduino program to change the program and just to get to know the new board. When I start the program it opens normal but if I want to change the Board options I only have Arduino options and for the Programmer I haven't got any option for the rpi. Like mentioned in this instruction:
https://projects.drogon.net/raspberry-p ... duino-ide/
I know it is for the gertboard but I also should have options like that? I hope you can help me with this problem!
I have another issue as well and hope you could help me with this one and I don't want to open a new topic because maybe they are connecting to each other.
I also have to say that if I just tried to 'sudo halt' or 'sudo poweroff' the raspberry with the gertduino the raspberry restarted after a couple of seconds. To shut down the rpi the only command which worked was:
sudo shutdown -h -H now
I have read in some other forums that this happened for other people to so I didn't bother.
Than I moved the jumper to configure the ATmega48p and tried to change the setup with the ./avrsetup.
Actually there are 2 options for the 48:
..3 for the Gertduino ATmega 48p at 8Mhz
..4 for the Gertduino ATmega 48p at 1Mhz
I tried both but I got these responses:
Oops -something went wrong, sorry...
But after I tried:
./program_48 low_power
the rpi shutdown and didn't reboot when I used only sudo reboot. So it seems that it uploaded the program to the atmega48. So can I just upload some new program without changing the ./avrsetup and only change the jumpers or do I have to change something? Maybe it is just a wrong version of avrdude?
Many thanks for help!
Cheers
Max
