jay123035
need specs for making ribbon cable
Thu Apr 10, 2014 3:30 pm
i wanted to make a custom ribbon cable for the raspberry pi. but i found that there is a LOT of ribbon cable on the market and i cannot find the exact specs.
this is what i found:TE CONNECTIVITY / MADISON CABLE 2-57051-4 FLAT CABLE, 26COND, 100FT, 28AWG, 150V
http://www.newark.com/te-connectivity-m ... dp/66F6277
specs
Conductor Area CSA: 0.072mm²
Conductor Size AWG: 28AWG
Jacket Color: -
Jacket Material: PVC (Polyvinyl Chloride)
No. of Conductors: 26
Pitch Spacing: 1mm
Reel Length (Imperial): 100ft
Reel Length (Metric): 30.48m
SVHC: To Be Advised
Voltage Rating: 150V
is this correct and if not what specs do i need to use?
Ravenous
Re: need specs for making ribbon cable
Thu Apr 10, 2014 4:23 pm
If you're connecting to the big GPIO connector on the raspi those are standard 0.1" spacing. So the spacing between your conductors should be 0.05". That one says 1mm pitch??
Best to check you are buying the right connectors to go onto it too! And whether you need a special tool to assemble the cable... Are you buying an entire reel, or just a few metres?
jay123035
Thu Apr 10, 2014 4:36 pm
i was hoping for a few meters. but if i have to buy a role i will.
this was the connector i was planning on using.
http://www.digikey.com/product-detail/e ... ND/3821470
Ravenous
Thu Apr 10, 2014 4:53 pm
Yeah that connector might be the right thing (0.1" pitch) but I think the cable you linked to is the wrong pitch. You probably want 0.05" pitch so they line up with the connectors.
Years ago (from my local suppliers) I was able to buy it by the metre, so look around if you don't want an entire reel!
Also make sure you can actually assemble the thing... there's meant to be a special tool, but squeezing slowly with a vice, so the connectors cut into the ribbon, might work....
jay123035
Thu Apr 10, 2014 6:25 pm
this is what i went with. thanks for all of the help.
http://www.digikey.com/product-detail/e ... -ND/686305
