bradlys
Re: 2.8" TFT + Touch Shield Board v2
Mon Sep 08, 2014 7:24 am
I used the the pre configured image and I have rerun the config many times with no avail. I appritiate the continued help with my problem thank you
texy
Mon Sep 08, 2014 10:27 am
so just to confirm, basically, the cursor does not move - it does not follow where you press down with the stylus, as indicated by the crosshairs?
Texy
bradlys
Sun Sep 21, 2014 3:46 am
Yes that is correct the cursor does not move at all I'm starting to think maybe its a hardware malfunction
texy
Mon Sep 22, 2014 11:42 am
on the assumption it is not software related, the usual problem in these cases is that the touch panel has been damaged. Can you check for
hairline cracks on the panel?
Texy
koko123
Sat Nov 22, 2014 9:02 pm
hi texy
i have a guestion can i buy only the kit for the touchscreen ? :?:
koko
georgeperkins
Mon Dec 08, 2014 12:20 am
Hi All,
I've been getting on really well with the TFT display supplied by Texy but have run into a problem when following Notro's Bootsplash article:
https://github.com/notro/fbtft/wiki/Bootsplash
I followed the steps without any errors but the "joy" bootsplash theme (as described in the instructions) looks a bit messed up.
I think it is best described with a video. I wonder if anyone can help figure out what is going wrong here:
https://www.youtube.com/watch?v=TGQMqHt ... e=youtu.be
Thanks!
Gman
Sun Jan 18, 2015 5:16 pm
Hi Texy, I have got the screen to display but am stuck with the touch configuration bit, when I dmesg I get back "ads7846 spi0.1: failed to request/setup pendown GPIO17: -16" . Please help, thanking you in advance.
texy
Sun Jan 18, 2015 5:53 pm
What image and Pi model are you using?
Texy
Gman
Sun Jan 18, 2015 6:04 pm
I'm got NOOBS SD card with the preloaded image and I'm using the B model pi.
texy
Sun Jan 18, 2015 6:32 pm
I strongly recommend you use the preconfigured image as per the first post of this thread.
Texy
Gman
Sun Jan 18, 2015 6:42 pm
Okay thanks, I'm busy downloading the image, do I just copy it to the SD card or how does it work?
Sorry for the noob questions
texy
Sun Jan 18, 2015 8:09 pm
Gman wrote:Okay thanks, I'm busy downloading the image, do I just copy it to the SD card or how does it work?
You do not just copy it to the SD card - you can use wins32diskimager, or google how to write an image to the sd card.
Texy
Gman
Sun Jan 18, 2015 8:41 pm
Great, thanks mate.
mahjongg
Sun Jan 18, 2015 8:46 pm
info about installing images is here: http://www.raspberrypi.org/documentatio ... ng-images/
for Linux, Mac OS or Windows.
ct1aic
Thu Feb 05, 2015 4:36 pm
Hi.
I still have the HY28A screen that I bought to eBay el_gringo69uk, last 25 Nov 2013. Do you still have the zip image for the RPI, that uses that old screen? The link http://tronnes.org/downloads/2014-01-07 ... -hy28a.zip is not found... :-(
Best regards.
Rui
texy
Thu Feb 05, 2015 5:38 pm
ct1aic wrote:Hi.
Best regards.
Rui
it seems that I didn't update the link when notro updated the image last time. Please try the link in this edited post :
http://www.raspberrypi.org/forums/viewt ... 81#p381681
Texy
texy
Sun Feb 22, 2015 10:33 am
has anyone who has used a HY28B display, such as the one used in my V2 display board successfully migrated to 3.18 with fbtft?
I cannot get the overlay to work, although the HY28A version works fine for my V1 boards.
As Notro has removed the HY28B overlay file from github until this is proven, I have attached it here as a zip file. You will need to unzip the file and put it in /boot/overlays directory and add dtoverlay=hy28b to the config.txt file, details here :
https://github.com/notro/fbtft/wiki#image-download
UPDATE : HY28B overlay is working - it seems I had a faulty display :?
Thanks,
Texy
hy28b-overlay.zip
(1.17 KiB) Downloaded 167 times
angusmedia
Tue Feb 24, 2015 6:58 pm
Is there an easy way to get openelec or OSMC/Raspbmc running with the texi-display yet? I also have a RPI2, too.
texy
Tue Feb 24, 2015 7:18 pm
angusmedia wrote:Is there an easy way to get openelec or OSMC/Raspbmc running with the texi-display yet? I also have a RPI2, too.
Not tried it for a very long time - let us know how you get on ;-)
Note the fbtft currently uses 3.18.5 kernel. If either of those media player OS' uses custom kernel, then it probably will not work.
Texy
texy
Sat Feb 28, 2015 11:07 pm
Try this :
http://blog.riyas.org/2014/07/quickly-t ... t.html?m=1
Texy
angusmedia
Thu Mar 05, 2015 3:43 pm
Raspbmc does not work yet on rpi2, osmc is just alpha status and has still too many bugs. I will have to wait.
ziki
Sun Mar 08, 2015 3:55 pm
Yes, I hope that OSMC (which looks fantastic even in alfa) will include fbdisplay ...
have a look here:
https://discourse.osmc.tv/t/fbtft-and-fbcp-in-osmc/231
miesch
Wed Apr 22, 2015 6:45 am
OSMC anyone?
Now that RaspBMC is no longer supported, I wanted to get my v2 TFT up and running with OSMC on my Raspberry Pi 2. This has been quite the undertaking for me as the RaspBMC instructions no longer work exactly as before. Mix these changes with the Device Tree introduced in the 3.18 kernel and this has been quite the learning opportunity! I have always appreciated how detailed and thorough Texy's instructions are. I would be glad to "pay it forward" and post instructions here if anyone is interested. Note that I am not using the touch screen at all, since I want to protect my screen. The screen fits *perfect* in this case (with the included extension).
The only thing I am stuck on is getting fbcp to auto start when Kodi launches. Since I am after max performance, I am updating the kernel with notro's DMA-enabled SPI FBTFT driver. After doing this, I noticed the boot console is shown rather than the OSMC splash screen. This isn't a problem, per se, except that I can only get the boot console to be mirrored. Once Kodi launches, the TFT goes black. Thus, the only way I can get Kodi mirrored on the TFT is to SSH into the box, when Kodi is running, and manually command it to run in the backgroud, ie:
fbcp &
Things I have tried:
  • Within /etc/rc.local, as notro did with startx here
Every time, it is the same. I can see the boot console on the TFT, but Kodi is not mirrored after that. It is worth noting that I have 4 raspberries at the top of the boot console, and only a single line warning about a deleted job. Not sure if it has something to do with that or not.
Does anyone have any ideas? Thanks,
-miesch
texy
Wed Apr 22, 2015 8:43 am
Good post ;)
Have you tried using cron with the @reboot option ?
Texy
miesch
Thu Apr 23, 2015 10:57 pm
Texy! I was hoping you would like that reprise of your initial RaspBMC post!
Thanks for the cron idea. I thought for sure that was going to do it. Unfortunately, I am still seeing the same thing. I know fbcp is automatically launching, as the boot console is displayed on my TFT (which by the way I do not see if I have not enabled automatic launch of fbcp). However, Kodi never shows up on the TFT, but I can see it on my primary monitor. Incidentally, in all of these cases, including cron, it seems fbcp is still running, even though Kodi is not being mirrored on the TFT. If I try to manually launch fbcp via SSH at this point, nothing happens (screen stays dark). If I try launching it again I get an error response:
osmc@osmc:~$ fbcp &
[1] 367
osmc@osmc:~$ fbcp &
[2] 372
osmc@osmc:~$ tvservice-client: Failed to connect to TV service: -1
It seems like since the boot console is shown instead of booting directly into Kodi, for some reason fbcp is being associated with that process. Everything I have read about fbcp indicates that it is not tied to a process or terminal, it just mirrors what is shown on the primary output. Any other ideas? Thanks a ton,
-miesch
