texy
HD44780 Large 20 x 4 display board, I2C
Wed Jan 01, 2014 4:24 pm
Instructions for basic setup and configuration of my I2C driven LCD board.
Configuration details for LCDproc and/or Raspbmc can be found here : http://www.raspberrypi.org/forum/viewto ... 35&t=63412
SSH into the pi and install smbus and i2c-tools :
sudo apt-get update
sudo apt-get install python-smbus i2c-tools -y
Enable i2c on the pi :
sudo nano /etc/modules
and add
i2c-bcm2708
i2c-dev
Also the I2C bus may be blacklisted by default so you need to remove it from the blacklist by
sudo nano /etc/modprobe.d/raspi-blacklist.conf
and putting a # at the beginning of the line 'blacklist i2c-bcm2708', so that it looks like this
#blacklist i2c-bcm2708
After saving reboot the pi
sudo reboot
Here is a python test program that displays on every line and detects button presses. It automatically detects if you are running a rev 1 or rev 2 pi also.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# working 24/11/13
# with backlight control
# and auto Pi Rev detection
import smbus
from time import *
import RPi.GPIO as GPIO
BackLight = True   # LCD backlight enable
Revision = 0       # Pi revision
UP=0
LEFT=0
DOWN=0
RIGHT=0
SELECT=0
# General i2c device class so that other devices can be added easily
class i2c_device:
   def __init__(self, addr, port):
      self.addr = addr
      self.bus = smbus.SMBus(port)
   def write(self, byte):
      if (BackLight == False):
         byte = byte & 0x7F # switch off backlight LED
      else:
         byte = byte | 0x80 # switch on backlight LED
      self.bus.write_byte(self.addr, byte)
   def read(self):
      return self.bus.read_byte(self.addr)
   def read_nbytes_data(self, data, n): # For sequential reads > 1 byte
      return self.bus.read_i2c_block_data(self.addr, data, n)
class lcd:
   #initializes objects and lcd
   pinout is as follows: PCF8574 - HD44780
   P0 - LCD11 - D4
   P1 - LCD12 - D5
   P2 - LCD13 - D6
   P3 - LCD14 - D7
   P4 - LCD4  - RS
   P5 - LCD5  - R/W
   P6 - LCD6  - E
   P7 - LCD15 - LED BACKLIGHT
      self.lcd_device = i2c_device(addr, port)
      self.lcd_device.write(0x03)
      self.lcd_strobe()
      sleep(0.0005)
      self.lcd_strobe()
      sleep(0.0005)
      self.lcd_strobe()
      sleep(0.0005)
      self.lcd_device.write(0x02)
      self.lcd_strobe()
      sleep(0.0005)
      self.lcd_write(0x28)
      self.lcd_write(0x08)
      self.lcd_write(0x01)
      self.lcd_write(0x06)
      self.lcd_write(0x0C)
   # clocks EN to latch command
   def lcd_strobe(self):
      self.lcd_device.write((self.lcd_device.read() | 0x40))
      self.lcd_device.write((self.lcd_device.read() & 0xbF))
   # write a command to lcd
   def lcd_write(self, cmd):
      self.lcd_device.write((cmd >> 4))
      hi= self.lcd_device.read()
      self.lcd_strobe()
      self.lcd_device.write((cmd & 0x0F))
      lo= self.lcd_device.read()
      self.lcd_strobe()
      self.lcd_device.write(0x0)
   #   print 'cmd',cmd,hi,lo
   # write a character to lcd (or character rom)
   def lcd_write_char(self, charvalue):
   #      print "char",charvalue
         self.lcd_device.write((0x10 | (charvalue >> 4)))
         self.lcd_strobe()
         self.lcd_device.write((0x10 | (charvalue & 0x0F)))
         self.lcd_strobe()
   # put char function
   def lcd_putc(self, char):
      self.lcd_write_char(ord(char))
   # put string function
   def lcd_puts(self, string, line):
      if line == 1:
         self.lcd_write(0x80)
      if line == 2:
         self.lcd_write(0xC0)
      if line == 3:
         self.lcd_write(0x94)
      if line == 4:
         self.lcd_write(0xD4)
      for char in string:
         self.lcd_putc(char)
   # clear lcd and set to home
   def lcd_clear(self):
      self.lcd_write(0x1)
      self.lcd_write(0x2)
   # add custom characters (0 - 7)
   def lcd_load_custon_chars(self, fontdata):
      self.lcd_device.bus.write(0x40);
      for char in fontdata:
         for line in char:
            self.lcd_write_char(line)
   def test(self):
      print("")
      print("toggle E x 10")
      for i in range(10):
         print(".")
         sleep(1)
         sleep(1)
      print("")
      print("toggle RS x 10")
      for i in range(10):
         print(".")
         self.lcd_device.write((self.lcd_device.read() | 0x10))
         sleep(1)
         self.lcd_device.write((self.lcd_device.read() & 0xEF))
         sleep(1)
def get_revision():
   with open('/proc/cpuinfo') as lines:
      for line in lines:
         if line.startswith('Revision'):
            return int(line[line.index(':') + 1:], 16) & 0xFFFF
   raise RuntimeError('No revision found.')
def get_board_revision():
   revision = get_revision()
   if revision in (2, 3):
      return 1
   else:
      return 2
def gpio_setup():
   global UP, DOWN, LEFT, RIGHT, SELECT
   if Revision==1:
      RIGHT=21
   else:
      RIGHT=27
   SELECT=4
   DOWN=17
   UP=22
   LEFT=23
   GPIO.setmode(GPIO.BCM)     # set up BCM GPIO numbering
   GPIO.setup(SELECT, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)    # set as input (Select button)
   GPIO.setup(UP, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)    # set as input (Up button)
   GPIO.setup(DOWN, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)    # set as input (Down button)
   GPIO.setup(RIGHT, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)    # set as input (Right button)
   GPIO.setup(LEFT, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)    # set as input (Left button)
def main():
      global Revision
      Revision = get_board_revision()
      print "get board revision=",Revision
      if Revision==1:
         i2cbus=0
      else:
         i2cbus=1
      print "i2cbus=",i2cbus
      device = lcd(0x20,i2cbus)
      gpio_setup()
      device.lcd_clear()
      device.lcd_puts("abcdefghijklmnopqrst",1)
      device.lcd_puts("1234567890abcdefghij",2)
      device.lcd_puts("ABCDEFGHIJKLMNOPQRST",3)
      device.lcd_puts("Line 4 - Hello !!!!!",4)
      sleep(3)
      device.lcd_clear()
      while True:
         if GPIO.input(SELECT): # if port 4 == 1
            device.lcd_puts("SELECT pressed   ",1)
            print "SELECT is 1/HIGH/True"
            if GPIO.input(UP):
               break # quit if SELECT an UP pressed at the same time
         elif GPIO.input(DOWN): # if port 17 == 1
            device.lcd_puts("DOWN pressed     ",1)
            print "DOWN is 1/HIGH/True"
         elif GPIO.input(RIGHT): # if port 21 or 27== 1
            device.lcd_puts("RIGHT pressed    ",1)
            print "RIGHT is 1/HIGH/True"
         elif GPIO.input(UP): # if port 22 == 1
            device.lcd_puts("UP pressed       ",1)
            print "UP is 1/HIGH/True"
         elif GPIO.input(LEFT): # if port 23 == 1
            device.lcd_puts("LEFT pressed     ",1)
            print "LEFT is 1/HIGH/True"
         else:
            device.lcd_puts("No button pressed",1)
if __name__ == '__main__':
    main()
Texy
cerebro
Re: HD44780 Large 20 x 4 display board, I2C
Mon Jan 27, 2014 11:43 pm
Texy's screen also works great on Volumio, the updated version of RaspyFi.
Download and install Volumio to an SD card, I have used a 2GB one but it is almost full, so I would recommend at least a 4GB card just to allow room for further expansion.
Once installed I would recommend connecting via LAN at first boot and from within Volumio's network setting you can set up your Wi-Fi network as required.
Follow the instructions as per viewtopic.php?f=35&t=63412 to get LCDproc installed. Once you get to the end of the instructions do not reboot, you need to enter a few more commands to get the screen to show what’s playing.
Enter the following:
sudo apt-get install python-mpd
sudo apt-get install python-pip
sudo pip install mpdlcd
wget -O "/etc/mpdlcd.conf" https://raw.github.com/rbarrois/mpdlcd/ ... pdlcd.conf
sudo update-rc.d LCDd defaults
You now need to make mpdlcd start at boot so use this command
sudo nano /etc/init.d/bootmisc.sh
and add this line to the file
su pi -c "mpdlcd --no-syslog &"
Close and save the file, now reboot (sudo reboot) .
At start up you should have an lcd screen that will show the track info you are playing. Credit to Andypi for the MPDLCD instructions.
Track info for Mp3's works fine, but on web radio streams you will get the song title and artist and the stream time but I have not found a way to change the name of the station as they all show as <Unknown> , if anyone knows how to solve this I would be most grateful if they could share the knowledge.
atomic3
Sun Jun 01, 2014 11:31 pm
I've tried setting up a 16x2 lcd using your tutorial, my pins are slightly different, how can I change them?
My P0 is actually VSS on the LCD.
cerebro
Sat Jun 07, 2014 12:40 pm
atomic3 wrote:I've tried setting up a 16x2 lcd using your tutorial, my pins are slightly different, how can I change them?
If you are using 16 x 2 try having a look at andypi.co.uk as he has a tutorial that includes the pins used to wire his screens.
Hope this helps
atomic3
Mon Jun 09, 2014 4:39 pm
Hope this helps
Unfortunately he's not using i2c PCF8574 which I have.
Thanks for the input though.
texy
Mon Jun 09, 2014 4:50 pm
You need to tell us more about how your chip is wired to your LCD. Also take a look at this part of the code, and adjust accordingly :
   P0 - LCD11 - D4
   P1 - LCD12 - D5
   P2 - LCD13 - D6
   P3 - LCD14 - D7
   P4 - LCD4  - RS
   P5 - LCD5  - R/W
   P6 - LCD6  - E
I don't understand why P0 would be permanently connected to VSS?
Texy
FTrevorGowen
Mon Jun 09, 2014 5:11 pm
texy wrote:You need to tell us more about how your chip is wired to your LCD. Also take a look at this part of the code, and adjust accordingly :
   P0 - LCD11 - D4
   P1 - LCD12 - D5
   P2 - LCD13 - D6
   P3 - LCD14 - D7
   P4 - LCD4  - RS
   P5 - LCD5  - R/W
   P6 - LCD6  - E
Texy
Hmm ... "the other configuration" . The two PCF8574-based backpacks I've used** have this setup:
P0 - RS
P1 - RW
P2 - E
P3 - Backlight via transistor buffer? & removable link
P4 - D4
P5 - D5
P6 - D6
P7 - D7
Trev.
** http://www.cpmspectrepi.webspace.virgin ... D_Backpack
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Douglas6
Mon Jun 09, 2014 6:24 pm
Is atomic3 confusing P0 (the expander chip) with LCD0 (the LCD module), which IS Vcc?
Nyonath
Thu Nov 27, 2014 3:48 pm
Hi there =)
I also tried to use this nice .py to control my display.
i also use i2c and pcf8574.
The only difference is my pin setup.
This is the standard setup:
P0 - LCD11 - D4
P1 - LCD12 - D5
P2 - LCD13 - D6
P3 - LCD14 - D7
P4 - LCD4 - RS
P5 - LCD5 - R/W
P6 - LCD6 - E
But my setup is like
P0 - LCD11 - D4
P1 - LCD12 - D5
P2 - LCD13 - D6
P3 - LCD14 - D7
P4 - NOT USED FOR LCD R/W is on ground cause i dont need to read only write.
P5 - LCD5 - RS
P6 - LCD6 - E
I tried to follow through programm with print s but the commands are shifted and operated with &, | so i cant fix the values to get it work. Display is flashing and blinking but not chars.
i also but all that gpio out cause i dont need it.
please help
FTrevorGowen
Fri Nov 28, 2014 8:55 am
FWIW, I've recently been testing a number of variations of the "4-bit interface", all with the LCD Read/¬Write line tied low ie. "Write only". This was mainly to check timing issues**** with various "port-expanding" chips. The schematics etc. can be found at:
http://www.cpmspectrepi.webspace.virgin ... alLCD.html
http://www.cpmspectrepi.webspace.virgin ... ut2p1.html
However, since I code in 'C', not Python I'm not sure whether that's of any help but, again, FWIW, a "snapshot" of the tarball can be found here**:
http://www.cpmspectrepi.webspace.virgin ... tware.html
Trev.
** or P.M. with contact details and I will e-mail the most up-to-date version.
Edit:
**** As posted here: http://www.raspberrypi.org/forums/viewt ... 00#p641100
cerebro
Sun Sep 25, 2016 11:01 pm
Hi Texy,
Does this code still work for Raspbain Jessie? Or do things need to changed to make it work?
Thanks in advance
