gmc
Using old Creative webcam with motion
Sat Sep 28, 2013 7:59 am
I've dug out my old Creative live mini webcam in that I'm hoping I can get it working with my pi.
I've installed motion, plugged in the webcam which gets detected:
Bus 001 Device 004: ID 05a9:0518 OmniVision Technologies, Inc. OV518 Webcam
In the messages log I see this when I startup motion:
Sep 28 08:57:20 weather motion: [1] cap.driver: "ov519"
Sep 28 08:57:20 weather motion: [1] cap.card: "USB Camera"
Sep 28 08:57:20 weather motion: [1] cap.bus_info: "usb-bcm2708_usb-1.2"
Sep 28 08:57:20 weather motion: [1] cap.capabilities=0x85000001
Sep 28 08:57:20 weather motion: [1] - VIDEO_CAPTURE
Sep 28 08:57:20 weather motion: [1] - READWRITE
Sep 28 08:57:20 weather motion: [1] - STREAMING
Sep 28 08:57:20 weather motion: [1] Config palette index 3 (JPEG) doesn't work.
Sep 28 08:57:20 weather motion: [1] Supported palettes:
Sep 28 08:57:20 weather motion: [1] 0: O518 (O518)
I've tried playing around with various options in the conf file with the palette but non of them work.
How do I get a a supported palette of O518 or is my camera too old :(
Oakham
Re: Using old Creative webcam with motion
Sat Sep 28, 2013 8:19 am
There are few posts regarding OV518/519 based webcams but no resolutions, though in an older Linux related posting it does state
"NOTE: The ov519 driver only works with applications that support JPEG video format"
http://www.lavrsen.dk/foswiki/bin/view/ ... ingDevices
Searching is easy, most questions have been asked before !
gmc
Sat Sep 28, 2013 8:53 am
Oakham wrote:There are few posts regarding OV518/519 based webcams but no resolutions, though in an older Linux related posting it does state
I would be happy if I could get it to just do screen captures.
Tried fswebcam but having no luck there either.
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
src_v4l2_get_capability,87: /dev/video0 information:
src_v4l2_get_capability,88: cap.driver: "ov519"
src_v4l2_get_capability,89: cap.card: "USB Camera"
src_v4l2_get_capability,90: cap.bus_info: "usb-bcm2708_usb-1.2"
src_v4l2_get_capability,91: cap.capabilities=0x85000001
src_v4l2_get_capability,92: - VIDEO_CAPTURE
src_v4l2_get_capability,101: - READWRITE
src_v4l2_get_capability,103: - STREAMING
No input was specified, using the first.
src_v4l2_set_input,181: /dev/video0: Input 0 information:
src_v4l2_set_input,182: name = "ov519"
src_v4l2_set_input,183: type = 00000002
src_v4l2_set_input,185: - CAMERA
src_v4l2_set_input,186: audioset = 00000000
src_v4l2_set_input,187: tuner = 00000000
src_v4l2_set_input,188: status = 00000000
src_v4l2_set_pix_format,541: Device offers the following V4L2 pixel formats:
src_v4l2_set_pix_format,554: 0: [0x3831354F] 'O518' (O518)
Unable to find a compatible palette format.
Oakham
Sat Sep 28, 2013 10:01 am
This was the old Linux Posting I found:
http://alpha.dyndns.org/ov511/cameras.html
http://alpha.dyndns.org/ov511/faq.html
They mention gqcam which is not in Debian Wheezy but was in Debian Sid, it may still be in the repostories !
http://www.wirelesscouch.net/software/gqcam/
gmc
Sat Sep 28, 2013 2:03 pm
Thanks for the info - tried that and couldnt get it going. Guess its time to retire the old cam.
I tried PC's newer webcam and it works flawlessly so I guess its time to get a compatible cam off eBay.
sirdel
Wed Nov 20, 2013 11:46 pm
I had the same problem with my old Creative Web Cam Model PD1030 running the latest kernel. I found an old Arch Arm distribution from last year 3.2.27-5 and it now works with fswebcam :)
LD_PRELOAD=/usr/lib/libv4l/v4l2convert.so fswebcam -r 320x240 -d /dev/video0 -p RGB24 -i 0 --no-banner image.jpg
Also, on my main Ubuntu x86_64 box (3.5.0-42) with the same gspca_main (2.14.0) & gspca_ov519 modules loaded I can get it to work as well with fswebcam, gstreamer, cheese, vlc etc :-
LD_PRELOAD=/usr/lib/x86_64-linux-gnu/libv4l/v4l2convert.so fswebcam -r 320x240 -d /dev/video0 -p RGB24 -i 0 --no-banner fsweb.jpg
gstreamer doesn't require the PRELOAD fix
gst-launch-0.10 v4l2src device=/dev/video0 num-buffers=100 ! 'video/x-raw-yuv,width=640,height=480' ! ffmpegcolorspace ! ffenc_mpeg4 ! queue ! avimux ! filesink location=movie.mpg
So it looks like somethings broken in the latest kernel :?:
pi
s1rdel.blogspot.de
