I am completely stuck. I have a reasonably standard USB bar code scanner that I have plugged into my Pi. It creates a /dev/hidraw0. The bar code scanner comes up as a "keyboard" on a computer (tried on several). What I want to do is have a program running in the background that reads the bar code scanner as a "keyboard" without having a terminal open.
The code that I am using is below. I found this type of thing on another board.
import sys
fp = open('/dev/hidraw0', 'rb')
while True:
buffer = fp.read(8)
for c in buffer:
if ord(c) > 0:
print ord(c)
print "\n"
When I run the code and scan the book I get:
38
36
37
39
32
30
39
36
31
30
34
35
36
40
I am really confused. I was hoping that somehow I could get a string, or the ASCII code of the ISBN. I am honestly not sure what the codes above are as they don't appear to coincide with the ISBN number.
Any help or thoughts would be greatly appreciated.
