jkeating
UART ATMEGA
Wed Aug 21, 2013 4:31 am
I am currently working on a project to read data from a GPS device and display that data on a LCD. Currently I'm using avr-gcc on the PI to program the AVR on the gertboard. The AVR is controlling the LCD and I'd also like the AVR to control/read the GPS device. Ive got the LCD up and running, now to the GPS. It uses UART but I'm not clear on how to connect things. I'm using a EM-406 GPS. Has anyone done this? I think reading the data will be pretty straight forward once I have everything connected right.
So I guess my question is how do I interface with the UART of the ATMEGA on the gertboard? I tried to find some reference in the forums but didn't find anything. Can someone point me in the right direction please? Much help is appreciated.
Gert van Loo
Re: UART ATMEGA
Wed Aug 21, 2013 12:27 pm
Connect the GPS UART to the D0 & D1 pins, but first make sure the TX-output of the GPS is 3V3.
(I don't know in how far the ATMEGA is 5V tolerant)
If not use a resistor divider of e.g. 5K6 + 3K3:
GPS TX --> 3K3 --> <point A> ---> Pi
<point A> --> 5K6 --> gnd
GPS TX goes to D1,
Atmega D0 goes to RX of GPS.
jkeating
Re: UART ATMEGA
Wed Aug 21, 2013 1:41 pm
Thanks for the reply Gert. Looking at my GPS's datasheet I found this:
ProtProtocol
Electrical Level: TTL level,
Output Voltage Level: 0V~2.85V
Baud Rate: 4800 bps
OuOutput Message: NMEA 0183 GGA, GSA,
GSV,
RRMC (VTG, GLL optional)
So the voltage being 0v-2.85V shouldn't need to worry about frying the atmega correct? Just plug it direct to the RX pin?
Gert van Loo
Re: UART ATMEGA
Wed Aug 21, 2013 6:32 pm
Yes.
