plichten
Edgeport USB to Serial Converter
Sun Aug 18, 2013 11:16 pm
I have an IO Digi Edgeport/4 USB to serial box that I would like to use with my Pi.
According to some Google Searches, it seems that the edgeport drivers should have been in Kernel 2.7+, but the Debian Devs have removed support from their Kernel. http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=548745
Is there any way to add the Edgeport into the current Wheezy? If not on a global scale, is it something I can "roll my own"? I've never built my own Kernel. All I am hoping to do is use the current version of Wheezy, but add support for the Edgeport.
Here is the output from dmesg:
[    5.005393] usbcore: registered new interface driver usbserial
[    5.083276] Registered led device: led0
[    5.088837] usbcore: registered new interface driver usbserial_generic
[    5.146381] USB Serial support registered for generic
[    5.322496] usbserial: USB Serial Driver core
[    5.486033] usbcore: registered new interface driver io_edgeport
[    5.721753] USB Serial support registered for Edgeport 2 port adapter
[    5.892764] USB Serial support registered for Edgeport 4 port adapter
[    6.044584] USB Serial support registered for Edgeport 8 port adapter
[    6.119371] USB Serial support registered for EPiC device
[    6.203326] io_edgeport 1-1.3:1.0: Edgeport 4 port adapter converter detected
[    6.314752] usb 1-1.3: Inside Out Networks Edgeport/4 detected
[    6.569890] Failed to load image "edgeport/down.fw" err -2
[    6.618238] Failed to load image "edgeport/boot.fw" err -2
[    6.649222] usb 1-1.3: Edgeport 4 port adapter converter now attached to ttyUSB0
[    6.681601] usb 1-1.3: Edgeport 4 port adapter converter now attached to ttyUSB1
[    6.705430] usb 1-1.3: Edgeport 4 port adapter converter now attached to ttyUSB2
[    6.727766] usb 1-1.3: Edgeport 4 port adapter converter now attached to ttyUSB3
gourmet-pi
Re: Edgeport USB to Serial Converter
Thu Aug 28, 2014 7:47 pm
I had the same problem getting my Edgeport USB to serial converter to work on the Raspberry Pi running Raspbian.
The Edgeport worked perfectly fine on my Mint Linux 13 laptop. But it would not work on the RPi.
The important information on the RPi in the error logging are the following lines:
The problem is some files are missing in raspbian. Look for /lib/firmware/edgeport/ and you may notice the directory and its contents are just not there.
So to "fix" this problem I simply copied over the files from my laptop to the RPi.
I simply copied over /lib/firmware/edgeport/ from mint 13 to the RPi and checked file permissions then rebooted the RPi.
Now I am no longer getting driver-firmware errors on RPi and getting green flashing light on edgeport indicating drivers are loaded and device is ready for use.
I can control the serial device(s) attached to the Edgeport/2. Life is sweet.
Barrygordon
Tue Oct 04, 2016 7:04 pm
Have you tried this on Raspbian Jessie? I would be very interested in getting a copy of the software you are using on Wheezy. Can you send me a copy or point me to a reference so I can download it?
Thanks in Advance
Barry Gordon
ovidiuivanica
Sat Nov 17, 2018 12:06 am
It worked for my Raspbian installation with the files I found here:
http://panda.moyix.net/~moyix/rpi/rpi_m ... /edgeport/
copy the files to /lib/firmware/edgeport
add execution rights to down3.bin
restart
Thank you guys !
Ovidiu
