Raspoootin
RTC That Just Works
Fri Apr 26, 2013 1:59 am
I need a RTC that I can install and the software to run it
is available via apt-get or is already included in the wheezy
distro. I'm not gonna go compile my own modules and source code.
So is there a clock that fits this?
I need plug-n-play.
scotty101
Re: RTC That Just Works
Fri Apr 26, 2013 8:37 am
http://learn.adafruit.com/adding-a-real ... t-rtc-time
If you don't want to compile your own code or install anything then perhaps raspberry pi isn't the right thing for you..
If you don't want to install a RTC then you might want to consider periodically updating the time from the internet.
ghans
Fri Apr 26, 2013 9:26 am
The linked tutorial is for the Adafruit Occidentialis distro
( and the RTC Adafruit sells for the Pi ) .
This might make things easier , but i believe your definition
of plug'n'play might only be matched by another ARM board.
ghans
Joe Schmoe
Fri Apr 26, 2013 10:17 am
The Internet is your RTC.
Raspoootin
Sat Apr 27, 2013 1:54 am
So there aren't any RTC modules with quick/easy software already included....yet. I'll check into the subject again later. As sales increase
and the market expands perhaps adafruit or someone else will do a
kit and have the wares included in the base debian distro.
I prefer to save my inner geek for other projects at this time.
Thx gurus.
BJNZ
Sat Apr 27, 2013 4:26 am
You could try the RasClock MODMYPI is selling. The hardware is ready assembled. Just insert the battery and plug into the Pi. You will have to do some software installing but the instructions are clear. It would probaly take less then 15 minutes all up.
Although I have built my own RTC adaptors I am going to try one out because it can fit in a case.
Brent
Sat Apr 27, 2013 6:11 am
Raspoootin wrote:So there aren't any RTC modules with quick/easy software already included....yet. I'll check into the subject again later. As sales increase
Thx gurus.
innergeek doesn't wear out/expire if you use it for stuff like this. It only wears out with age.
rudiratlos
Tue Apr 30, 2013 9:30 am
This works with std. linux drivers. No compiling needed.
http://shop.basis.biz/shop/Raspberry-PI ... ack-board/
asandford
Tue Apr 30, 2013 7:23 pm
This works with just 4 wires, supported by hwclock:
http://dx.com/p/high-accuracy-ds3231-mo ... lue-168974
Takes a couple of weeks to deliver to UK
Joe Schmoe
Tue Apr 30, 2013 8:42 pm
asandford wrote:This works with just 4 wires, supported by hwclock:
What's the hookup between that board and the Pi?
asandford
Wed May 01, 2013 4:52 pm
Joe Schmoe wrote:What's the hookup between that board and the Pi?
It connects to the I2C bus and is read by hwclock -r
pi@raspberrypi ~ $  i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@raspberrypi ~ $ hwclock -r
Wed 01 May 2013 17:48:33 BST  -0.959643 seconds
pi@raspberrypi ~ $
Joe Schmoe
Wed May 01, 2013 5:41 pm
Could you please be more explicit?
What connects to what?
asandford
Wed May 01, 2013 7:12 pm
Joe Schmoe wrote:Could you please be more explicit?
RTC Board     PI GPIO Header
GND    ------> GND (Pin 9 / 25 / 20 / 14 / 6)
VCC    ------> 3V3 (Pin 1 / 17)
SDA    ------> SDA (Pin 3)
SCL    ------> SCL (Pin 5)
Joe Schmoe
Wed May 01, 2013 10:38 pm
Thanks.
I love it when people are explicit.
