driftking96
Cheap Good Quality Wi-Fi Adapter or Wi-Fi/Bluetooth Combo
Sun Mar 10, 2013 8:59 pm
Hi guys,
I'm about to get a Raspberry Pi right now and I would like to get a cheap, good quality Wi-Fi or Wi-Fi and Bluetooth combo adapter so that i can get everything i want as soon as i get my Raspberry Pi. Anybody know of any adapters?
Thanks :D
FTrevorGowen
Re: Cheap Good Quality Wi-Fi Adapter or Wi-Fi/Bluetooth Comb
Tue Mar 12, 2013 11:17 pm
I've found the newer devices of those I've made notes about here (http://www.cpmspectrepi.webspace.virgin ... pters.html) O.K. - they're all "just a few pounds". However, WiFi dongles can be "power hungry" when trying to connect, requiring upto 500mA briefly, hence you'll need a good quality PSU and, depending on other USB bits & bobs "in use", possibly a powered USB hub. The small bluetooth dongles, like their cousins for other wireless HID devices, are less demanding, but you will have to download additional bluetooth supporting packages (for Raspbian) IIRC they're not part of the "basic image".
Trev.
IanH
Wed Mar 13, 2013 9:22 pm
For what it's worth, I've tried 3 dongles so far, all on Raspbian Wheezy:
  • CPC/Farnell Wi-Pi - Ralink chipset, connected OK, but lots of problems for me: got very hot & caused kernel panic after an hour or two. Maybe I had a bad unit, can't believe they really this flaky.
  • Maplin N150. Ralink again, worked out of the box. Have seen a couple of disconnects, possibly related to power-saving mode - see thread http://www.raspberrypi.org/phpBB3/viewt ... 46&t=16257 .
  • TP-Link TL-WN821N: Realtek RTL8192 chip, worked out of the box. Haven't seen any problems with this so far.
https://github.com/IanHarvey
driftking96
Sat Mar 16, 2013 2:54 pm
Thanks Guys, I think i will do a little more research on some more adapters before i pick one.
Appreciate the help. :D
zaxxon007
Thu Mar 21, 2013 1:25 pm
I use this one:
ImageUltra-Mini Nano USB 2.0 802.11n 150Mbps Wifi/WLAN Wireless Network Adapter
It works with B/G/N and is capable of receiving HD stream without packet loss.
sej7278
Thu Mar 21, 2013 3:58 pm
Realtek RTL8188CUS (same as the edup mentioned): http://www.ebay.co.uk/itm/290826199518
Ralink RT5370: http://www.ebay.co.uk/itm/300573160837
both work out of the box on raspbian (in fact i can swap between the two in my pi without reconfiguring anything!) for under a fiver.
that said, both seem to cause a small hum when used with usb/analogue audio out (not hdmi) but i'm starting to wonder if that's my hub or psu (the hum goes away if you unplug the wifi....)
for more have a look at: http://elinux.org/RPi_VerifiedPeriphera ... i_Adapters
tonyhughes
Thu Mar 21, 2013 7:19 pm
This WiFi b/g/n nano adapter works great out of the box with Raspbian.
https://www.modmypi.com/raspberry-pi-ac ... Fi-dongle)
cppxaxa
Mon Feb 16, 2015 4:55 pm
A Realtek RTL8188EU 802.11 works for me in Raspbian with firmware-realtek which I am selling in ebay india
http://www.ebay.in/itm/WiFi-Adapter-for ... 1289422861
If asked I can check new adapters and sell them with drivers .. it was a pain to find cheap and reliable working wifi adapters for raspberry pi in india.
