silverfox0786
Need Help and also a WARNING - DO NOT TRY THIS AT HOME
Thu Feb 21, 2013 3:35 pm
I have the V2 gertboard and wanted to put a pin connector on the GPIO
the desoldering was a nightmare and do not try it yourself
i completly made a pigs ear of it
well here is my question i managed to rig the pins with kaynar wire and get them working
what i need help on is i lost 3v3 and wher can i connect that so i can get that back
https://dl.dropbox.com/u/37235863/2013- ... .30.10.jpg
Gert van Loo
Re: Need Help and also a WARNING - DO NOT TRY THIS AT HOME
Thu Feb 21, 2013 5:02 pm
The 3V3 comes from a voltage regulator on the Gertboard.
That needs 5V from the Raspberry-Pi:
Connect Pin 2 and/or 4 (both have 5V) to either (or both) pins of J24.
silverfox0786
Thu Feb 21, 2013 9:57 pm
Thanks gert but i think i didnt address my question properly
i still have the regulated 3v3 runnign from pin 2 going to J24
what i lost is direct from RasPi Pin 1 3v3 which powers the onboard 3v3 points directly from pi
what i noticed from doing a few conectivity tests is I could connect pin 1 to header J7 middle pin and that then seems to redistribte the 3v3 back again
would that be a good idea
silverfox0786
Fri Feb 22, 2013 1:26 am
doing more reseach myself i found this
looks like i need header J7 going to bottom pin 3
outlined as pink track
btw on a off topic do you have the track scematics for the new version 2 board
Gert van Loo
Fri Feb 22, 2013 11:52 am
I will see when I have time to generate a track picture and post it.
At the moment I am having major issues with SCRIBD where I can't post new
documents for unknown reasons but also that they do not reply on my (multiple) requests for help
for the last two weeks!!!!
I am now contemplating taking all my data down from their site and use somebody different.
If I forget, Just keep prodding me about this, I don't mind.
silverfox0786
Fri Feb 22, 2013 7:45 pm
thanks gert
although now im gonna use this patched up one as a dev board and really grind into it and gonna buy a new one for delicate work :) hehe
hope your getting royalty for each sale of the gerboard
one thing can i suggest for a possible version 3
to have a stacker conenctor so it can be connected direct from bottom or plugged into cable at top
or even give the user the choice by leaving teh connector for the end user to solder in
thanks
Papa G
Sun Feb 24, 2013 12:12 am
silverfox0786 wrote: one thing can i suggest for a possible version 3
thanks
I second the motion. :) I suppose that in order to maintain for everyone the usefulness right out of the box, the stacker connector would be the best option.
