therimmer96
GPIO LED's
Thu Jan 31, 2013 4:25 pm
is there any pins on the pi that no matter what, will send power down when the device is on? i would like to be able to have some white power indicators for my custom case
cheers
James
PS1981
Re: GPIO LED's
Thu Jan 31, 2013 5:59 pm
As far as I know the 3,3v and 5v pins are always on when the pi is powered up.
pjc123
Re: GPIO LED's
Sat Feb 02, 2013 12:47 am
If you also would like an LED to tell you that the pi has safely shutdown, then you can use GPIO 14 (Connector PIN # 8) UART TXD. It will turn off after the file systems have been safely unmounted. I have an LED for that and an LED connected to my pi power supply, mounted on the front of my chassis.
My Raspberry Pi Project Page:
https://www.flaminghellmet.com/launch/
