shermanpk
IR I/O via GPIO
Thu Jan 31, 2013 10:11 am
I am looking for a board or to make a board that I can use to connect an inferred receiver and transmitter (and perhaps an LCD display) making use of the GPIO port. I can do / have done most of the programming (a friend of mine is a recent programming graduate) and is looking for things to do.
Any off the shelf parts? or will I have to get a soldering kit and some parts?
MattHawkinsUK
Re: IR I/O via GPIO
Thu Jan 31, 2013 11:06 am
If you want a basic LCD screen (16x2 or 20x4) then these are cheap and easy to interface with the GPIO
Image:
16×2 LCD Module Control With Backlight Switch
http://www.raspberrypi-spy.co.uk/2012/0 ... ht-switch/
20×4 LCD Module Control Using Python
http://www.raspberrypi-spy.co.uk/2012/0 ... ng-python/
The interface is mainly a few wires and some resistors. I added a transistor so I could turn the backlight on and off.
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
rudiratlos
Re: IR I/O via GPIO
Thu Jan 31, 2013 3:15 pm
the new piggy-back board (rev2) will have IR receiver and IR transmitter.
LCD Display can be connected via serial port or via I2C (see a nice OLED device: http://www.seeedstudio.com/depot/grove- ... th=163_167)
I think that the rev2 board will be available in 1-2 weeks from now.
shermanpk
Re: IR I/O via GPIO
Thu Jan 31, 2013 11:09 pm
Hi rudiratlos, do you have a link to the Piggyback board (rev2)?
I can't find it.
Thanks for the quick reply.
slimjim
Re: IR I/O via GPIO
Thu Jan 31, 2013 11:24 pm
There are some kits around like this one at Sparkfun: https://www.sparkfun.com/products/10732
I'm pretty sure that I've seen some assembled ones as well, but I can't find a link right now. I've built one myself... so it's not that hard ;)
I've written up a post on setting up the Raspberry Pi to send/receive IR signals and there's a web interface that can control the LED:
http://randomtutor.blogspot.co.uk/2013/ ... ry-pi.html
I've used the LIRC module for the IR controls, which needs the latest firmware installed on the Pi.
