Reset pin on ATMega328
Posted: Thu Jan 24, 2013 8:55 pm
by brgibson
Is there any good way to access the PC6/DBG/RESET pin on the ATmega? I can't seem to find it on any of the headers. I want to add a hardware reset to my mega program but don't want to have to solder a wire to the anode of D19 to get to the reset line.
Nevermind, I found it hiding (in plain sight) on the J23 header!
Re: Reset pin on ATMega328
Posted: Thu Jan 24, 2013 8:58 pm
by domesday
You will find reset on the ICSP header.
Posted: Fri Jan 25, 2013 4:34 pm
by hillbilly
So how do you reset the ATMega328 ?
Posted: Fri Jan 25, 2013 5:27 pm
by Gert van Loo
You pull pin 1 low.
Which is also available as PC6 or on pin 5 of J29.
J29 is numbered:
1 - 2
3 - 4
5 - 6
Just don't pull pin 2 low as that has 3V3 on it, so you will short circtuit your supply if you do that.
