jahnavi
RS232 Shield With Raspberry Pi
Wed Jan 16, 2013 7:36 am
Is there any RS232 Shield that can be used with Raspberry Pi.
Thank you
Arjan
Re: RS232 Shield With Raspberry Pi
Wed Jan 16, 2013 5:47 pm
http://www.raspberrypi-dmx.org/
Open Source DMX/RDM/MIDI/OSC/Art-Net/sACN solutions
jfornango
Contact: Yahoo Messenger
Fri Jan 18, 2013 3:41 pm
Sweet little board.
You'll need to pay attention to your project, though. I checked XBit's website. The board is available with either a 5V or 3V3 level shifter.
I'm only wearing black until they find something darker.
TonyD
Sun Jan 20, 2013 9:11 pm
There are a number of RS232 boards for the RPi.
PartCo of Finland stock this one
Tony
NathanBookham
Fri Feb 08, 2013 2:51 pm
You can also get Arduino shield adapters so that you can use Arduino shields with the RPi.
http://www.cooking-hacks.com/index.php/ ... ion-bridge
This account is now inactive.
I am now known as 'InverseSandwich'
and101
Mon Feb 11, 2013 10:57 am
AB Electronics have just released an expansion board which supports RS232 and 1-Wire.
http://www.abelectronics.co.uk/products ... and-1-Wire
itsmedoofer
Tue Dec 09, 2014 12:40 pm
I use the RasPiComm,
http://www.amescon.com/products/raspicomm.aspx
Great little product...
Martin.,
klricks
Tue Dec 09, 2014 2:59 pm
There are many available.
Note: The module must have a MAX3232 chip (not MAX232) and the chip or module needs to be powered by 3V3 (not 5V).
Some info on my web site: http://home.budget.net/~klricks/Comp/RPi/Serial.html
crazepony
Thu Dec 11, 2014 2:45 am
I would like to recommend this module available in amazon web site.
http://www.amazon.com/dp/B00N8CNZPO
If you want to use the GPIOs at the same time.A 3-row GPIO extended board is a good choice.
http://www.amazon.com/dp/B00N8C992W
If you are using RPI B+ board,the B+ GPIO to B GPIO convert board is a nice choice.So you could use all your RPI B module add-ons in the RPI B+ board.
http://www.amazon.com/dp/B00PLP7NM2
kreisler
Mon Jun 26, 2017 3:46 pm
Does anyone have experience with this seemingly(?) new GPIO Serial Port Expansion Board RS232 For Raspberry Pi (SKU:1102755) ?
It costs 15US$ on ebay and aliexpress, so the banggood link seems to be the cheapest.
I would need a male-to-male gender changer, for 0.69US$ :x
Question: Does one need to install a driver, or are RS232 shields functional right away like Plug'n Play?
kreisler
Wed Jul 19, 2017 10:42 am
kreisler wrote:Does anyone have experience with this
Hello, i've got that BG serial board. As soon as the raspi is powered, the green LED on the BG serial board lights up.
I am on the latest Raspbian Jessie, and i deleted the serial-console entry; things seem to look good so far:
So how do i know, by which simple raspi tests/commands or program/utility, that my Pi Hat and its RS232-port is fully functional and working perfectly as it should? I have connected my logging digital multimeter (LDMM), with the help of a male-male gender changer, to the RS232-port, thus the BG serial board should be receiving data/signals all the time.
Btw i do have Raspbian beta-software for my LDMM but it seems that the software is not receiving any data/signal thru the raspi/Pi Hat/Gender Changer, so i need to question the functionality of the Pi Hat first!
Thanks in advance for some help or pointers!!
Gord_Fi
Thu May 02, 2019 11:21 pm
I have the same board and had a heck of a time getting it to work on my Stone TFT display board. I found the C soure code that's found in here works ok and tried communicating with my laptop. I used my laptop to setup the TFT display and couldn't figure out why it wouldn't work on the Raspberry Pi3. Well, I reversed the TXD and RXD wires on the TFT display and it started working just fine. Likely because the cable for Pi to Laptop was (I forgot the term) but made for computer to computer communictaion where the RX/TX terminals are reversed in the cable. Sometimes it's stupid simple things that get stuff working. Good luck with your project.
