Overheat in altitude
Posted: Thu Feb 06, 2020 12:34 am
by Rosalie
My team and Iwould like to know if the fan on the Raspberry Pi PoE HAT is really necessary for its good functioning ? We are building a stratospheric balloon which we'll send in the stratosphere (around 35 km from the earth). However, at this altitude there's no heat and there's no area pressure. So, we don't think that the fan would send fresh air to refresh the motor. In short, does the fan on the Raspberry Pi PoE HAT in this case is really needful?
Also, at which temperature does the fan starts spinning and which temperature the Raspberry Pi can no longer operate?
Rosalie
Re: Overheat in altitude
Posted: Thu Feb 06, 2020 8:29 am
by rpdom
Why would you be using a PoE HAT in a balloon? Surely it would be better to power the Pi from some sort of battery supply with a 5V regulator circuit.
Posted: Thu Feb 06, 2020 8:32 am
by rpiMike
Why are you using a PoE HAT on a balloon? I’m guessing the Pi will be powered by a battery?
