soldering iron temperature for gertboard
Posted: Tue Dec 18, 2012 4:29 pm
by Andybp
Hi....
I have a gertboard coming for xmas from my lovely wife.
I plan on building it over christmas.
Coudl anyone recommend the temperate I should set my soldering iron to please?
I'll be using 60/40 tin/lead roson core
Re: soldering oron temperature for gertboard
Posted: Tue Dec 18, 2012 5:15 pm
by Burngate
No more than 400C - in my experience.
To a certain extent, it will depend on the size of your bit, thinner ones needing a higher temperature (the sensor is at the other end of the bit, and you've got to allow for a drop down the length, as well as the thermal capacity being lower ...)
And I'm expecting more people to chime in here with different ideas.
Posted: Tue Dec 18, 2012 5:33 pm
by aTao
Heres my 2 bit's worth (see what I did there?)
For more years soldering than I care to admit to, a Weller TCP 24 has done just about everything. I have a PT A A 7 bit, its pretty damned fine and set for 370C.
Money you spend on a good high power temperature controlled iron is money you will never* regret spending. Cheap tools are the biggest cause of problems with hobby electronics.
* Never ever say "never". (oops)
Posted: Tue Dec 18, 2012 5:56 pm
by Andybp
Thank you.
Posted: Wed Dec 19, 2012 3:18 pm
by plugwash
I usually solder at 350.
higher temps mean quicker melting but they also mean the solder left on the bit oxidises quicker and shorten tip life.
