olio
gertbot and GPIO pins access from below
Fri Dec 06, 2019 12:32 pm
I use two Gertbots to run 3 stepper motors and one DC motor. Additionally, I would like to install a 3.5 inch Adafruit TFT display (PiTFTplus). What would be the smartest way to access the GPIO pins below the Gertbot?
Is there a probably a stack-on connector with a flat cable comes out side-wards, that I can stack between Pi and Gertbot?
Greetings and thanks for any hint!
Oliver
thagrol
Re: gertbot and GPIO pins access from below
Fri Dec 06, 2019 3:50 pm
You don't have to mount the gertbot directly on the Pi's gpio. See section 4.9 of the gerbot manual: https://www.gertbot.com/gbdownload/rev2 ... al_2.8.pdf
Assuming there is no pin conflict pick one of the many products that convert the Pi's single gpio header to multiple ones.
A few to get you started (other products and other suppliers exist):
https://www.ebay.co.uk/itm/Butterfly-Al ... wMcUBoncvg
https://shop.pimoroni.com/products/phat ... 8973360138
https://shop.pimoroni.com/products/pico-hat-hacker
https://shop.pimoroni.com/products/mini ... 9448026055
olio
Mon Dec 09, 2019 8:16 am
Hello thagrol,
many thanks for the hint...in fact I didn't look at this part and should have found the solution by myself;-( I appreciate also the links for the GPIO multiplier parts...I like the pico hat hacker.
Greetings and have a good day!
Oliver
