MKa
cm3plus does not read id eeprom at boot
Wed Sep 04, 2019 9:08 am
Hi!
We have made a board with CM3+ module attached. We try using HAT EEPROM for board identification/configuration. I have managed creating/loading EEPROM contents by following https://www.raspberrypi.org/forums/view ... p?t=108134 procedure. Write procedure can be verified from SCL0/SDA0 lines. However those lines are dead during boot procedure and no hat folder is present in /proc/device-tree directory.
I have added ID_SDA and ID_SCL definitions in dt-blob.dts and compiled it to /boot/dt-blob.dts (and back for verification). Those lines include:
pins_cm3 section/pin_config:
            pin@p0  { function = "i2c0";   termination = "pull_up"; }; // I2C 0 SDA
            pin@p1  { function = "i2c0";   termination = "pull_up"; }; // I2C 0 SCL
pins_cm3 section/pin_defines:
            pin_define@ID_SDA {
               type = "internal";
               number = <0>;
            pin_define@ID_SCL {
               type = "internal";
               number = <1>;
Also based on the hint from https://www.raspberrypi.org/forums/view ... p?t=179330 by 6by9
I added "force_eeprom_read=1" statement to /boot/config.txt
Still, nothing happens in SDA0/SCL0 at boot.
What configuration have I missed?
Tanks,
Matti
PhilE
Re: cm3plus does not read id eeprom at boot
Wed Sep 04, 2019 1:47 pm
Are you sure your dt-blob.bin is being used? Try modifying some other pin, e.g. make GPIO4 an output, and verify with raspi-gpio that it is taking effect.
And do use external pull-ups - the internal pull-ups aren't strong enough for I2C.
MKa
Thu Sep 05, 2019 5:43 am
It started to work when I took pin@p0 and pin@p1 definitions from dt-blob away. Some devices with pin_define@ID_SDA/ID_SCL seem to have them and some don't. Well, this is something I need not understanding.
6by9
Thu Sep 05, 2019 7:26 am
pin@p0 and pin@p1 are only present in pins_rev2 (original Pi A or B, 256MB or 512MB), which doesn't support HATs.
They are not required as the firmware adjusts the pin muxing during probing the HAT, and should put it back again afterwards.
