Andyroo
[Solved] Pimoroni Inky pHAT not updating
Thu May 16, 2019 2:04 pm
If you have a Pimoroni Inky pHAT and it stops updating after a boot just check you are not powering the Pi via the USB ports - for some reason you have to go through the actual power connector for it to work...
Only enough, the display software just seems to hang - I assume at some point it would time out but I gave up by then.
Took me awhile to spot this (Pi zero is upside down) as the Pi was working fine and of course the display showed the last message :lol:
