Mafia8540
Re: Usb dvb
Fri May 03, 2019 7:02 pm
6by9 wrote:
Thu May 02, 2019 1:14 pm
Mafia8540 wrote:
Thu May 02, 2019 12:55 pm
Resultat of lsusb is
  Bus 001 Device 007: ID 15f4:0131 HanfTek
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
So based on "15f4:0131 Hanftek", your device is an AstroMeta DVB-T2 or clone thereof, and in some variants it's supported by Linux - https://github.com/raspberrypi/linux/bl ... xu.c#L1942
See https://linuxtv.org/wiki/index.php/Astrometa_DVB-T2 for the full status, paying attention to the comment about the update in 2018. Support for the 2018 update appears to have been added in Linux 5.0, whilst we're supporting 4.19 (it is a long term support kernel). If you have a 2018 variant then you'll need to build your own kernel.
I first tested this
https://linuxtv.org/wiki/index.php/How_ ... ernel_tree
[*]git clone --depth=1 git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git linux_media
cd linux_media
   git remote add linuxtv git://linuxtv.org/media_tree.git
   git remote update
   git checkout -b media-master remotes/linuxtv/master
git pull . remotes/linuxtv/master
git rebase remotes/linuxtv/master
make oldconfig
make olddefconfig
make localmodconfig
make xconfig
make gconfig
make
and finally when I write
make modules_install install
it tells me a mistake
the present kernel configuration has modules disabled
