Killertechno
Pi Zero Enc28j60 Network Adapter Module
Tue Apr 09, 2019 4:41 pm
I was searching for ENC28J60 network adapter, I bought a ENC28J60 network adapter made for Arduino, it didn't work, so I bought a new one specific for Zero (but correctly working also on Pi 2B).
Ok, this board is more expensive than Arduino one (I paid about 18 euro on Amazon), but I haven't wasted time to check for correct cable connections to try to understand why it doesn't work even if connections are ok...
http://wiki.52pi.com/index.php/Pi_Zero_ ... U:_EP-0088
I had just to add "dtoverlay=enc28j60" on /boot/config.txt and at next boot new ethernet port already available.
The only one think I don't like it's at every boot it takes different MAC address, so my router is giving it every time a different IP....
I know there is a way to fix MAC address in some configuration file.
Killertechno
Re: Pi Zero Enc28j60 Network Adapter Module
Tue Apr 09, 2019 4:44 pm
DirkS
Tue Apr 09, 2019 6:42 pm
viewtopic.php?f=28&t=209309#p1452371 is what I use to get fixed MAC addresses on my ENC860s
HermannSW
Wed Apr 10, 2019 9:16 am
I was able to use exactly those cheap Arduino modules with Pi Zero three years ago, see the instruction links:
viewtopic.php?t=152965#p1015300
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
Killertechno
Tue Jun 04, 2019 7:34 am
I already follower those instructions, that's why, due not working, I moved to another board.
Without creating new discussions: I would like to make ENC28J60 HAT where I can power off module when I don't use it.
I can't find discussion again, to do this I must:
- unload kernel module
rmmod enc28j60
- power off enc28j60 (I don't remember if on Raspberry input terminals I need to put pull-up or pull-down resistors, or leave it in hi-Z)
- power on enc28j60
- restart module
sudo insmod enc28j60
Am I missing something?
